I have been thinking about this a lot lately. Seems that with the 2.5 inch lift there's not a ton of stuff to replace other than springs, shocks and caster bushings. Then add in the swaybar spacers (optional for some) and extended brake lines and that's about it. With that you can easily run a 33 inch tire or perhaps a 35 with rubbing. Now, a 6 inch lift requires replacing a lot of stuff to make it work. It's a sweet set-up, but it's pricey.
I was thinking stay with the 2.5 lift and get portaltek to slap some portal boxes on the ends of your 80 axles. I know you may lose some highway cruising gearing (or maybe not i'm not really sure). This way you will have the ability to run at least 35 or 37 inch tires and have a minimal lift to keep the center of gravity low. Also, all the driveline components such as front/rear driveshafts, panhard rods, control arms ect... will not need to be replaced.
Any thoughts on this?
