Some of yall recommended putting grease into the square valve behind the rotor, into the birfield joint. What grease would yall recommend to put on the birfield?
and both of those I'm going to be able to put into that square valve and feed into the birfield?
...knowing it wont go into the joint itself where its needed most?
..........Really,,, the new has mixed fully with the old in every rig that I have owned. It lubes the birf, knuckle bearings and spindle bushing as intended.
I've taken to removing the quick coupler from the flex hose and just insert the male threaded end. Much less mess that way.
Why does it have to be moly fortified? What would be wrong with something like Coastal Premium Hi-Temp Grease?
80t0ylc - Is this the stuff you are referring to from napa? : Product Information -- SL3330 -- Moly-Graph® Extreme Pressure Multi-Purpose Lithium Grease, 14 Wt Oz
Just started my search to pick some up to "top-off" mine.
Any other thoughts from you guys on this stuff?
