RTH: Pulled factory alarm, now no CEL light
I just got finished pulling the factory RS3200 alarm system from my 97 fzj. Removal seemed pretty straight forward, no wires were cut, a couple of splices removed. The battery was disconnected during removal. Once I mated all the connections up, the truck will turn over no problem but won't fire.
I also noticed the check engine light does not come on when I insert the key and turn it to acc before starting, which I'm pretty sure it did and I'm pretty sure I read somewhere that if it doesn't come on you have an ECU issue.
I've tried re-mating all the connections that I was into and still no CEL comes up.
I also installed a CDL switch at the same time, but thats so mundane I don't see how it would have effected this.
The only issue I could think of was maybe the wire splices broke a wire when getting removed?
Anyone have any ideas?
Ryan
Ryan
