Tripometer
Commerce, CA
Greetings All,
My tripometer suddenly stopped working. Has anyone repaired or replaced one of these? Is it labor intensive or expensive? Thanks for your support. I searched the threads but did not find anything.
:beer: Go Lakers!
Did you try pressing the reset button? Shot in the dark fix.:meh:
If it stopped working, but your speedo and odo work, I would say ignore it. The fix is likely a new speedo unit.
Yes. I pressed it. Odometer and Speedo work. I must be a small gear or something keeping it from working.
What does the tripometer read now? Do the numbers roll like the odometer and you just can't reset it? I've had tripometers on other rigs act up: one wouldn't reset to zero unless you pushed it several times in a row hard. Others would reset, but wouldn't roll until you tapped the reset button a few times. Try jiggling the reset button several times, sometimes dirt or dried grease inside unit will cause reset mechanism to hang up and disable it temporarily.
You have to push it a few times and it will reset. When you drive it usually does not mark the numbers.
Sounds like you have a mechanical gremlin in there, possibly dirt or dried lube. Trouble is - the combo meter (instrument cluster) where this is - is very fragile and needs to be handled GENTLY when serviced. I've had mine out to do the temp. gauge mod, but didn't look at the trip & odometer so I can't be of much help there. Maybe some one that's done it can chime in to help.
What year is your rig? Temp gauge mod is mainly for the FZJ80s ('93-'97) If you're going to take it apart to look at it, I recommend this:
1. Read up on the temp. gauge mod for familiarity, first.
2. Do the temp gauge mod while in there (if you have '93-'97).
3. Replace any and all burnt out bulbs in your cluster at this time.
I do believe in Gremlins... My Rig is an 96. Funny you mention the bulb because the left side went out. Used the good old Fonzy tap on the dash and it came back on. Aaayyyyyy. I know it is just a matter of time before it goes. I will read what you recommended. Thanks for your help.
One sidenote I personal like the fact my D (drive) indicator is out LOL. Not going to replace mine ;)
My '96 has the same issue. The trip odometer is supported by a pretty weak plastic frame in the back, which doesn't seem to stand up to very much resetting. The only "fix" I could find was to buy another speedometer and replace the whole unit. They are pretty hard to find, unless you want one a whole bunch of miles.
If you keep wiggling it, it will reset, but it may keep track of all of the miles, it may not, kind of like rolling the dice. You may want to just write down the miles from the odometer and keep track of it that way. Anyhow I had no problem finding other things to spend money on, then replacing the speedo.
Hope this helps.
RM
I guess I killed it!!! When I fill it tank up, I reset it out of habit just to see how far I could go. Nothing a piece of paper and a pen won't fix. Sometimes it works but then it gives out. Oh well.
I have the same issue. The speedo first starter to only work when the car is warm, then started to jump, the ODO still worked fine. I fiddeled with the wires and then the speedo and ODO stoped working. I replaced the speedo sensor ont he transfercase, but it still does not work...
Any ideas?
