OK,
So after some advice from the crazy dash lights, i thought I'd check my alt connections to make sure all was in good order. I was glad to see the main power cable bolt was a little loose which was likely causing all of the lights to flicker on bumps. There were quite a few metal shavings that were magnatized etc since it's likely been that way for a while.
I went to tighten it a bit and the stud was so worn, it snapped at the lightest touch. So now....how screwed am I?
Is the stud servicable. I'd love a quick fix while it's in the truck
