... What grease do you use to lube it?
Most wheel bearing and other high speed greases aren't a good choice, they are made to relatively easily give up their oil and move around to lube roller bearings. This would make a mess in the actuator.
The grease that I use is a silicone based thick grease made for air tool gears. The label is gone, but IIRC it's from IR and have no idea where you would get it. But your looking for a thick, almost waxy, stay in place type grease. Maybe try electronics type store for thick silicone grease or a tool/nut & bolt type store for tool (grinder, saw, drill) grease?
Must of the bushings are blind holes, so if they are packed with too much grease it can bind the unit. I "pregrease" the bushings, put some in the bushing hole and on the shaft, fit the shaft, make sure it bottoms in the hole and turns freely, add/remove grease as needed. When all of the parts "fit" properly, then do final assembly. It's a balance, you want as much grease in there as possible, but not too much, causing a bind or getting on the motor parts, etc.
The same goes for the sealer, most of the time the o-rings are trashed, I seal them with silicone sealer. You want enough to seal it water tight, a small bead squeezed all of the way around to show a good seal, but not huge gobs that could get into the works.
