Belated free(!) advice on how to remove a balky OEM roof rack!
I'm really annoyed with my roof rack guys...
I'm down to the last spnining stuck screw/nutsert but it won't budge...
Fed up!
I made a major mistake when trying to remove the screws, so here is my take on how to do this best:
At the slightest sign of screw balkiness to unscrewing, stop! Don't force it! First douse the thing with Kroil for a period of week (s). It may not go in and may not do anything any way cuz these screws are sealed with some by now hard clay like material.
Try again, gently.
If there is still resistance, STOP!
Proceed to drill all the balky screw heads. This sounds drastic but it is really easy, will only take an hour. You can then simply lift all the brackets out. It is MUCH better than the dreadful alternative I have to contend with: You got a screw frozen into the nutsert and if you put too much torque on it, the nutsert starts spinning and you can't remove the screw or mount anymore, and you also can't drill the screw head out anymore, sadly, and it won't come off. There are then 2 obvious ways to deal with it: saw through the bracket mount or remove the headliner. The first choice busts the rack set, the second is a pain.
On the other hand, if you drill all the screws out, and remove the rack, you have now full access to the screws and nutserts to Kroil them, superglue them, torque them off, anything you want. Much better
So be smart, don't do what I did!
dang little
enjoy!
E
(added: this may not work with the skinny rails, I'll have to check what happens when you drill the heads on those. The body of the screw may still hold the endpiece in place... more later)
added: don't actually douse the thing with Kroil, it could stain your headliner. I did it one drop at a time over a period of many days. No stain noted, but then it turned out that most of the screws were sealed with some bizarre goop, dried by now.
Fed up!
Try again, gently.
dang little
enjoy!
E
