Today my A/C started acting 'goofy'. It works as long as the variable slide control is set to the coldest setting. If I move it just a little to the right for warmer air it immediately starts blowing HOT air. Any ideas what this might be? Thanks
If it's the automatic system, you can take out the control unit (remove it from the dash), and flip a switch in the back which makes it completely manual.
Does the CE 80 have the automatic climate control like the LX and 80 AEs do? Reason I ask is that my '97 40th AE does the same thing...You either have full hot or full cold, nothing between. It was like this when we bought it and haven't really tried to figure it out yet. The guy I bought the rig from said Toyota told him it was a $120 part.
I did some MUD searching but I didn't find anything all that close to the problem. There was a thread about something on the firewall that you needed to watch while someone moved the temp controls (how's that for fuzzy info) to see if it moved in relation to the temp slider...If it didn't you needed to fix that dealyo
Anyway, sorry I'm not much help but I'll be watching to see if you figure it out as it may solve my problem as well![]()
Really? Is the switch clearly a switch? Thanks for the info.
Yeah, we've got the same problem, but mine just started doing this today...bummer. Funny thing is...I just had a XM Radio installed yesterday and the installer was bumping 'stuff' all back there.
Hmmm...maybe they forgot to reinstall one of the controllers? Did they have to take the face trim/surround off to get the XM radio installed?
I'd check just for piece of mind. Take out the ashtray, remove the two screws in that slot, pop out the little tray deal at the top and remove the two screws there and that face piece comes off with all the buttons etc attached.
thinks TX80Fan and I are heros now
