100A Alternator
As some of you may recall I installed a Mean Green alternator in the hopes of getting more amps for my system. I had it tested and it puts out 78A which is what the stock amp puts out (80). Granted it is nice and heavy duty, but I wanted more amps. There is not a whole lot of space to work with for a different alternator, but I found a stock one that will work good. It's a Delco Remy 1101466Y 100 Amp. Pretty simple job. Just pull the Delco pulley, install the Toyota stock two belt pulley (it fits perfectly) and tighten down. You need a small bushing or washers (about 5/16") to make up the difference in the top mount and you do need to make up a bottom adjusting bracket as the Delco is farther left than the Toyota. Stock belts line up perfectly. Oh, I did buy two of the Delco's so I would have a backup.
Pic is of the Delco stock.
Bill
Pic installed.
>> Oh, I did buy two of the Delco's so I would have a backup <<
Bill, We've never met but I've heard that you're into redundant systems. I heard right!
:cheers: Riley
