NorCalBorn
- Joined
- Aug 31, 2008
- Threads
- 102
- Messages
- 1,856
Input and feedback here is appreciated, as I hope to figure out why this happened as everything else is in great running condition. Hopefully I have simplified my issue here and worded it good enough.
OK, this is on my 4Runner, the headers are Thorley ceramics, DynoMax 2" inlet/outlet catalytic converter, into a Flowmaster single in/out with 2.25" tailpipe.
My first indication was a little snap/ping/bang sound while driving today. I parked it, let things cool down, and went around the system with a small rubber mallet to isolate the rattle/ping I was now hearing from my exhaust. It literally sounded like a bunch of Cv bearings bouncing around. I then dropped the converter to find the primary honeycomb (there are two in the thing) cracked into pieces.
For reference: *Notice the Converter's Heat Cured Stainless, purplish-red and yellow, the rear's still that color, only the front section is blued out. The HoneyCombs are each located where the raised ribs are in the pic..air gap's probably about an inch or so between them.
No scorching, no clogs visible, just the first honeycomb cracked apart and the metal around it all blued up now. *I did find a small piece of the old exhaust donut in with the stuff, could it have been sitting there, resting just in front of the primary honeycomb glowing really hot and caused enough of a hot spot to crack the ceramic? The weather was around 50 degrees this morning and it happened shortly after warm up.
My plan is to take it down tomorrow and get a warranty part.
Honestly though, it makes me question DynoMax quality and just think I should have gone with the MagnaFlow California Carb legal one instead.
*Maybe this is partially why California pushed for the new legislation? I'm hearing of a couple other people having problems with these Dynomax catalytic converter system parts.
