Howdy folks,
My thread here will not be nearly as exciting as the others I have read, but I'm still honored that it is the ROTM for March.
I previously owned a 91 Toyota 4x4 Pickup and became interested in off-roading after going on a several trail rides with a friend of mine. I was going to set my truck up to be more capable for where I wanted to take it, but quickly realized that I would be dumping more money into it then I was comfortable with considering it had been re-done two years prior. It was set up more for looks and comfort then capability, so it made no since to "re-invest" more cash into it.
I sold it as it was in early June 09, and began my search for a DD/rig that had what I wanted. I happened to see a for sale thread on here and contacted the owner. After several emails and phone call's I flew down to Texas and looked at it. I knew it needed some work, but it had everything I wanted in the way of capability, so we struck a deal on August 1, 09.
I have replaced the items that needed immediate attention like the pitman arm, idler arm, sway bar bushings, CV axles, brake booster, master cylinder, turned the rear drums, alignment, new KM2 tires, etc...
I have also fixed the smaller "convenience" items like the fan blower switch, re-worked the sunroof switch (made one good out of two bad switches) trouble shot the CB power issue, re-worked the CB Mic connector, cleaned the carpets, re-worked and lubricated the rear tailgate guts and glass regulator, added a 3 outlet 12v hub, etc...
Due to life being as hectic as it was the second half of 09, I was never able to get off-road with it to any extent. I was finally able to get some serious trails under it's belt the first weekend in February. I went down to North Georgia for a GATTORA Rescue Tellico event as well as a ride hosted by Offroad Outfitters.
During the Offroad Outfitters ride I had some breakage happen just before the last hill to get out of the area we were in. I grenaded the right CV axle and at the same time my rear ARB locker decided to disengage and not work again (air leak). So stuck with no four wheel drive and no rear locker, it had to be rescued. With the help of my buddies (misterzee) SAS'ed 87 4Runner and a Jeep, it was pulled up the muddy hill. It made it out threw all the mud in two wheel drive to the main road and then my buddy's Zack & Mike were kind enough to swap out the CV for me. Justin at Offroad Outfitters was very kind to allow us to use his shop / lift to get it done. Yet another testament to how well the off-road community helps out it's fellow members. It was my first time meeting him!
My rear ARB will need to be fixed as will the rear diff. It is making sound when you let off the gas at speeds over 50mph. This is my next fix just as soon as my bank account will allow it. It won't be cheap. A 1" front diff drop from 4Crawler has been put in to reduce possible CV bind.
I know that some of you probably expected a build up thread, but since it was just not financially feasible at the time to build up, I bought one already built. For what I sold my truck for I was able to transition from a street truck to a capable rig. It just made financial since at the time. I know I will still learn quite a few new skills from wrenching on this 4Runner.
Spec's:
1992 Toyota 4Runner Sr5 V6 3.Slow
Suspension:
OME Front/Rear Shocks N72f/N98
OME Steering Stabilizer SD33
OME HD springs HD901
SDORI BJ spacers
SDORI custom 1" Rear coil Spacers
Downey Pan Hard Bracket
Sway-a-way Torsion Bars
Sonoran Steel Rear front lower control arm Truss
Drive Line:
Warn Premium Hubs
Yukon 4:88 gears
ARB front & rear Air Lockers w/ARB Big Compressor
Hayden Transmission Cooler
Wheels & Tires:
Late model SR5 alloy wheels with 33X10.5X15 BFG MT KM2's
Also a set of ProComp 33x12.5x15 XTerrain's on black 15X10 Mods.
Protection:
ARB Winch Bumper
Warn M8000 Winch
Big Country Customs Rear Bumper w/ Swing Arm Tire Carrier
Custom Kick out Sliders from Rock Tec
Additional Adds:
Optima Battery Red Top
BVG Roof Rack Basket
(6) 55w halogen lights
48"Hi Lift
KayMar Hi lift and Shovel holder
Safari Snorkel
Bushwhacker Flares
Cobra CB
Toyota CD player
Rechargable Fire Extinguisher
Spec's:
Suspension:
SDORI BJ spacers
Drive Line:
Warn Premium Hubs
Yukon 4:88 gears
Wheels & Tires:
Protection:
ARB Winch Bumper
Warn M8000 Winch
Additional Adds:
48"Hi Lift
Safari Snorkel
Bushwhacker Flares
Cobra CB
Toyota CD player
