I'll go ahead and say, this is my first engine build, I have been reading a lot on here trying to learn as much as I can but still have questions.
Just found a machine shop to do my work on the engine and before I go to drop it off I would like a critique/suggestions on what I should have done and what I should not have done before I walk in there.
My 40 is mainly a trail rig so I'm planning on focusing this build around that.
It will stay below 3k rpm 99% of the time
Want high torque at low rpm
93 octane is fine, doesn't get driven enough for it to be a problem
For the Block:
.040 or .060 pistons? .060 is max from what i've read, but is it worth it? or just stick with .02 or .04 (assuming it can machined to those 2 sizes)
Crank needs to be cleaned up
Lifters resurfaced
Balance Piston, Rods, and Crank.
Camshaft: delta 262 degree cam
For the Head:
SBC valves or stock toyota's? Seems the SBC bump compression and flow better
Port and Polish, it's crossed my mind, but is it beneficial on a tractor motor?
Anything suggestions/recommendations are greatly appreciated.
For the Block:
Lifters resurfaced
For the Head:
Pull .1 off the head.SEV-3091 and SEV-2809+100 valves from here: http://www.rpmrons.com/SIvalvesclaimer.html
