I took my emissions system down for a complete desmog (keeping HAC, decel fuel cut, CO, stock carb/distributor) and I discovered that the "gas filter" was preciously jb welded and then broken off and abandoned to breathe fresh air.
This first photo is the vacuum source as it was before disassembly.
The second is what I have done to the manifold so far.
The third is the source I plan to use for my desmog.
I had to tap out the forward port to 1/8 npt to get a brass fitting to thread in securely. The aft vacuum port is plugged with a square headed brass fitting but only finger tight because I was not sure I could source vacuum this way and I wanted to be sure i could thread this weird (fj40?) vac port back in somewhere if I had to.
My question is this: Why are there two ports cut into the mani and are they different? Is one better? Is this cobbled brass fitting a reliable way to get vacuum?
