oem vacuum tubing (1 Viewer)
hward1
87 fj60 / 95 fjz80
CA for little while
hey has anyone recently bought oem vacuum tubing -- how much was it and how much length and sizes were needed --
Toyota doesn't sell tubing by the foot, but sells pre-cut lenghts (I think this holds true for any tubing, not just vacuum). The small diameter vacuum tubing comes in three lengths: 300mm, 600mm and 950mm. If you are just changing one, then you would purchase the appropriate length, then cut it to size.
However, if you do a search you will find that the 950mm length is much cheaper (on a per foot basis) than the other two. So if you are changing all the lines you're better off just buying a bunch of 950mm lengths. If you do a search you will find that the total length people use a around 30 - 35 feet. 950mm = approximately three feet (a little less).
Do the search...
You will find you need 35-40 feet of 3mm and 10 feet of 6mm
Macmaster carr
#5041k52 and #5041k54
$1.33 and $1.10 per foot.
Now just pick your favorite color!
