Ok...another crazy question... I'll go look through the FAQ and search around as well.
What are concerns with running a GM NV4500 manual 5 speed trans behind my 5.7 Vortec?
Need trans to TC adapter?
What about slave cylinder setup?
What about clutch arm?
exhaust clearance issues? Can you run stock manifolds?
assume regular GM clutch would work?
assume I would use GM bellhousing and GM version of the NV4500. I recall reading that there are numberous configurations on this trans... what to look for?
allready have GM 5.7 , and I think the flywheel is 168 teeth (not sure of the exact tooth count as I type this (is a stock GM flywheel).
So generally speaking I would swap in new clutch, nv4500 trans, and TC adapter...sit engine where I wanted it... and fab up crossmember and engine mounts to match. Get new driveshafts.
Just under consideration....wondering about the "fine print".
