So when I bought my truck a few months back the carb fan worked and now not so much. It just quit one day no alarming sounds from the fan just not on when I turn off the motor. DOes anyone know if there is a fuse and where it may be???
Mine was recently acting up. I could hear the relay clicking on and off behind the driver's side kick panel. I pulled the kick panel and wiggled the relay (very technical approach). All seems to work fine now.
Butt
I'll be jumping back in there sometime later this week because mine is acting up again. I'll grab a pic if someone doesn't post something up first. I may just ground the wire and be done with it.I had clicking sounds coming from the under the dash as well when the fan was running, then it just stopped working, anyone got a pic of the relay in the kick panel area?
thanks
cool steering wheel, is it OEM?The dome fuse is the 7.5 amp fuse in the upper right corner of the fuse box. There should be a legend on the inside of the cover plate
