Fj62 + 2fe + h55
About a year ago i picked up a 89 with a knock. The oil galley plug had been replaced with a bolt, I figured the bottom end would be toast, but it was cheap. I didn't realize how expensive it is to rebuild a 3F, so i'm going to swap in the 2f. I can buy a donor 60 and rebuild the motor for less than the 3F rebuild. After the third donor truck i finally have a good crank. While i'm there, figure i might as well swap out the tranny. After researching here on mud it seams like a pretty straight forward swap for both the motor and tranny. Some light fabbing on the tranny cross-member and brackets on the motor. I'll post my progress an i go so you guys that have done these swaps can add your .02.
the brown 60 is an 83 where I got the 2F i'm using and the 62 is in the back ground
