As the title says.....
I got the ARK3004 from Ridetech.com
I got a 2.5" OME Heavy on the back.
Here are some pics...
This are the two brakets that the kit comes with...
I did not know you had to order the air hose and Presta valves separate
This the little spacer/bearing/ring/ whatever.. that goes on top of the leaf pack and under the axle. The bottom bracket has to be drilled out to 1" to accept the spacer.
Drilled out....
Drilled out....
