There has been alot of talk lately about VR.....i have an 1983 with an internal VR....i needed to replace mine so i have outlined it for those who may have to do in the future. all you need is a phillips head screw driver, a wrench to remove battery cable, emory cloth to clean contacts, and 15 minutes...
replacement voltage regulator was $24.00 from rockauto...standard products part # VR160....shipped in two days for $6.00 to VA
voltage regulator has 7 screws total....two on the top cap, two on the side cap, and three on the VR contact leads...
remove the battery cable.....
remove the side cover screws and cover,
remove the terminal screws,
remove the top cover screws and pull straight up on VR.
