I'm guessing the info is out there but I haven't gotten the right search words apparently.
First question is on the pulley. I've heard the F-motor alt. pulley will bolt onto the GM alternator. Is this true? If so, is it a pretty small diameter so this thing will have decent output at low RPMs?
As for wiring of it, I know the Battery cable goes......well to the battery and I know this will make the alt. work just fine. But with the other 2 factory wires, what needs to be done there? I'm guessing one is for the charge lamp but I thought I heard once it can only use 3 amps or something. And also what of the other wire?
Any help is much appreciated as I'm looking to get my winch installed, as well as my CB and radio.
I thought I had read somewhere that if one of the other wires wasn't tied in somewhere that the charge light would be constantly on. Curious if this is true and if so, can it take 12 volts or does it need to be knocked down.
Looking forward to adding some more electronic stuff now.
