I can't seem to find anyone selling a radiator with more than 4 rows... I'm wondering why? My 3B with a turbo puts a lot of heat into the loop, the stock rad is already 4 row but I want to upgrade it.
Well fxxx, I was googling for 6 row and got zip.
Its already got a big fixed fan and a good shroud, etc etc. The problem is overheating at highway speeds, its just fine at idle -
I would look into where the heat is coming from. Depending on your setup, you may not have enough air getting in to burn the fuel efficiently. This will lead to hot exhaust, hot turbo, heated intake charge, higher engine operating temps..
You may need an intercooler. less restrictive intake plumbing or a less restrictive exhaust system.
OR... you may need to flush your radiator if it is old and possibly clogged. A good four core Cruiser rad should have no problem cooling a properly running 3B w/turbo.
If you are running a clutch fan (best choice) make sure the clutch is working correctly. A bad fan clutch can cause overheating at highway speeds too. I ran in circles for a while a few years back installing brand new aftermarket fan clutches that were not locking up soon enough or hard enough. Installed OEM fan clutches in the two rigs i was fighting with and solved the problem.
This is Ratpuke's old Rig that you are dealing with, yes?
In answer to you original question. More than 4 rows start loosing effectiveness. and size can be a problem too.
A more modern aftermarket cross flow radiator made of AL will cool better (AL is not as good for heat transfer, but the cross flow design is better).
Mark...
..Tom at least one rad is brand new. What should concern you, given your anti-additional-gauge philosophy is that 220f only reads at halfway on the stock gauge. (in the bj42... The 73 gauge claims a redline at about 220)
Even so, I am surprised by your "1/2 scale = 220 oF".
Where did you get that from?
And I don't recall seeing many BJ42 owners (turbo or non-turbo) complaining that their stock radiator isn't up to the job.
Most people don't have a second temperature gauge installed to compare REAL values. Both of my trucks do, however.
