So, in my quest to build a new gauge panel, (that and my fuel sending unit was bad) I started buying gauges, today I received my AM Fuel Gauge & AM Universal Sending Unit
and proceeded to install the SU, first thing I noticed was I had to modify the plate (screw holes didn't line up), I checked the tank depth, STEM length and float length, cut the float arm to the recommended length, installed and wired up the gauge.
After turning the FJ on, with gas in the tank (not much, about less than 1/4 tank full, I plan to fill the tank tomorrow morning), the gauge barely moved up to the 'E' on the gauge.
My only concern is the setup, it was hard to get the tank depth, I figured it at 9" (bottom of the hole for the sending unit mount, to the bottom of the tank where the dip is at the bottom).
I want to know if anyone has experience with installing the above listed parts in a stock fj40 (1974) tank.
