So, I bought the 3 speed transfer case to 4 speed transmission kit from Downey. I removed the PTO gear and added the spacer, and then reinstalled everything. The problem is, the input gear on the transmission output shaft doesn't match up with the gear in the transfer case (see pic). I have about an 1/8" between the gear and the pto spacer. That's about the same distance the gears are off set. I went for a quick test drive, and the gear whine is bad - I figured it would be. I'm concerned this isn't going to work and/or prematurely wear all these parts out.
So, what am I going to have to do? Do I need to shim the gear back about an 1/8", or is it okay? I know the gear whine will diminish a bit once the gears wear together awhile, but right now it is LOUD.
The pictures are through the pto cover. On the left is the new gear on the tranny output shaft. You can see the pto spacer sleeve above it. Everything is torqued to spec.
Any suggestions or help would be greatly appreciated.
Thanks!
Thanks!
