air cleaner
Why don't you use the F aircleaner? I ran (temporarily) an aftermarket aircleaner held on with a hose clamp. The carb is a 3" throat....but you already knew that.
GL
Ed
'79
I assume by your user name and avatar pic you have a '79?
If so, by looking at the pic below ('79 ish) there's not another choice unless you fab up some sort of adapter, then again, there's nothing to hold it down but the stud........
Grant, he must be running a pre '75 carb to be asking the question. Otherwise, the answer is too simple;)
'79........How long was the bus you rode to school:D
Here's one using a Weber box welded to a 3" 90* vent pipe elbow used on gas hot water heaters........:eek:
I can get you 3 more configurations when I return to work on Monday....:D
I LIKE that s***!!!!:D
