Alright, so I have a 2F swapped into a '72, with a rebuilt Weber (not sure which). I'm losing power under acceleration. The engine runs OK at idle, but not great, since I still haven't got the carb tuned fully yet. It get's an occasional sputter at cruising speed, but not too much.
From everything I've found here, it sounds like it's probably a fuel supply issue, but I want to rule out every simple option before putting out cash for a new pump. Since this started last week, I've replaced the filter, and cleaned out the tank (even though there didn't seem to be any problems when I took out the sender and peeked in). I've also verified that there don't seem to be any clogs in the lines.
Anything else I should look into before ordering a pump? Anything else that could be the problem?
