Recently acquired a speed calibrator from Slee for my 06 UZJ100. Reading this thread, I figured that the 06 would be a little different than the 2000 model. Looked through the EWD and this is what I found:
I need to intercept the signal from the VSS the red/green wire on pin 6 of the IX1 connector.
The IX1 connector is right behind the glove box so this should be a relatively easy install.
job if you feel comfortable reading a wiring diagram and soldering connections. I soldered all the connections on mine.
