Old 11-23-03, 06:28 PM   #1
tltaylor22's Avatar
tltaylor22
Garage heat
I've got a 1200 sq ft garage seperate from my house and have a list a mile long to do to the 40 and the 80 this winter. I'm looking for some type of heating unit. I'm in favour of some sort of built in unit as apposed to a space heater. Any suggestions?
tltaylor22 is offline   Reply With Quote
Old 11-23-03, 06:42 PM   #2
cruiser_guy's Avatar
TLCA# 16387
cruiser_guy is on a distinguished road
Garage heat
It depends alot on what fuel source you have available and how high the ceiling is. I'd be tempted to use a unit heater or a radiant tube heater if you have natural gas or propane available but you'd need at least a 10 or 12' ceiling so you don't burn yourself if you get too close!
Old 11-24-03, 10:49 AM   #3
How did I get here?
yooper's Avatar
TLCA# 13011
yooper is on a distinguished road
Re:Garage heat
I don't like having flame in the garage, so I went with electric oil filled radiators. Works good - more expensive than gas, though.
yooper is offline   Reply With Quote
Old 11-24-03, 10:20 PM   #4
tltaylor22's Avatar
tltaylor22
Re:Garage heat
I think I could lay a gas line out there, actually thinking of putting in a bathroom too. Wife hates her kitchen sink turning black when I wash my hands. I hadn't thought of the radiant overhead heat. The rafters are 10'. I use the space above for storage.
Old 11-24-03, 10:34 PM   #5
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Poser is on a distinguished road
Garage heat
I have a radiant heat tube spanning the 60' section of my 40x60. I have an eleven foot roof. It is fired off Propane. Works real well. Not sure if I would want to have it in any closer to the ground, as it heats objects, and it does a damn fine job! I was in a 25x20 that I heated with a old home furnace. It worked well, but the radiant heat is a far better set up.
-Steve
Old 11-25-03, 02:28 AM   #6
hammerhead's Avatar
hammerhead
Re:Garage heat
I live in the mountains where fire wood is abundant and free. Fire hazard is not an issue since I'm a welder and everything was already setup for safety all the way down to the chemical cabinets. With the fan on, it only takes about 30 minutes to bring it up to a comfortable temp, from the 10 degree area. I can even cook my lunch on it or make a hot beverage for the trail (I've been known to skip out for some wheeling on slow days or to test a mod on my 40).
hammerhead is offline   Reply With Quote
Old 12-01-03, 08:21 PM   #7
NOT Yoopers Avatar!
PHAT MAX's Avatar
PHAT MAX is an unknown quantity at this point
Garage heat
we use a natural gas heater mounted on the wall....works great!
cruiserrg uses radiant floor heating and he says that if he spills water, it is evaporated 1/2 hour later! sweet!
PHAT MAX is offline   Reply With Quote
Old 12-02-03, 09:59 AM   #8
dinkleberry
Re:Garage heat
Waste oil heaters:
http://www.lanair.com/home.cfm
http://www.americasprideonline.com/W...%20.FrameIndex
dinkleberry is offline   Reply With Quote
Old 12-02-03, 08:56 PM   #9
dylan
Re:Garage heat
[quote author=Dinkleberry link=board=14;threadid=7948;start=msg70152#msg7015 2 date=1070384390]
Waste oil heaters:
[/quote]
dylan is offline   Reply With Quote
Old 12-03-03, 03:53 AM   #10
IDave's Avatar
TLCA# 13705
IDave is an unknown quantity at this point
Garage heat
My mechanic has one of those. I change my oil a lot, but not enough to justify one of those!!
IDave is online now   Reply With Quote
Old 12-03-03, 05:34 PM   #11
dinkleberry
Garage heat
The garage I used to share with a few others had an old one. The owner picked it up used. Don't think it was too expensive.
Uninsulated barn in the middle of winter and it would cook you out. We used to accept oil from friends and neighbors and never ran out.
Old 12-03-03, 07:30 PM   #12
Junk's Avatar
Junk is on a distinguished road
Re:Garage heat
Waste oil heaters:
http://www.lanair.com/home.cfm[/quote]
Hmm. Any heater website that has a built in ROI calculator is a hint it's a little out of my range.
I prefer forced hot air like this
Junk is offline   Reply With Quote
Old 12-05-03, 03:32 PM   #13
dinkleberry
Re:Garage heat
You've got a point (on top of yer head). I have to admit I didn't actually look at those prices til now.
[quote author=Junk link=board=14;threadid=7948;start=msg70929#msg7092 9 date=1070505038]
[/quote]
I'm sure you can produce enough to heat a few garages!
Old 12-09-03, 04:57 PM   #14
the shed guy's Avatar
the shed guy is an unknown quantity at this point
Garage heat
We made this from a couple of truck brake drums, choke in the square top bit, ash drawer and air control on the bottom, steel band around the middle, and the top is great for heating stuff, and is open in the pic, and is where you drop the wood in.....
the shed guy is offline   Reply With Quote
Old 12-14-03, 10:22 AM   #15
Sir_Titus is on a distinguished road
Re:Garage heat
Wood heat is the best way to go, plus you can heat up dolar store chili on it that will help you heat it with your own natural gas like junk
Sir_Titus is offline   Reply With Quote
Old 12-15-03, 01:18 PM   #16
nuclearlemon's Avatar
TLCA# 1431
nuclearlemon is an unknown quantity at this point
Garage heat
[quote author=the shedguy [Aus/CAC] link=board=14;threadid=7948;start=msg73504#msg7350 4 date=1071014222]
[/quote]
just make sure you have a good floor...those drums get heavy real quick
nuclearlemon is offline   Reply With Quote
Old 12-19-03, 08:07 AM   #17
kstatecruiser's Avatar
kstatecruiser
Garage heat
I know you said no space heaters, but I'm partial a the "jet engine" space heaters. I don't know what they are really called, but the ones that run on kerosene or diesel fuel. Even a small one can heat up a large area quickly.
kstatecruiser is offline   Reply With Quote
Old 12-19-03, 11:43 AM   #18
I lurk there for I am!
Niner's Avatar
TLCA# 13372
Niner is an unknown quantity at this point
Garage heat
[quote author=kstatecruiser link=board=14;threadid=7948;start=msg77753#msg7775 3 date=1071846435]
[/quote]
Around here we call those salamanders, or torpedo heaters.
Niner is offline   Reply With Quote
Old 12-19-03, 11:50 AM   #19
Admin
woody's Avatar
TLCA# 1548
woody will become famous soon enough
Re:Garage heat
I'm in the middle of installing a 75k BTU Hot Dawg heater from Modine....propane or natural gas, mounts 1" from the ceiling, 3" external exhaust, electric fans, thermostat controlled. Hope to fire it this weekend....should heat my 4-stall nicely.
Old 12-19-03, 07:48 PM   #20
Junk's Avatar
Re:Garage heat
[quote author=woody link=board=14;threadid=7948;start=msg77904#msg7790 4 date=1071859858]
I'm in the middle of installing a 75k BTU Hot Dawg heater from Modine....propane or natural gas, mounts 1" from the ceiling, 3" external exhaust, electric fans, thermostat controlled. Hope to fire it this weekend....should heat my 4-stall nicely.[/quote]
Pic and estimate please.
Old 12-23-03, 03:45 PM   #21
Bad Homburger
FJ40-GARAGE's Avatar
TLCA# 6289
FJ40-GARAGE
Garage heat
[/quote]
Guess you mean something like http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=2582407743
this ?
Thats a Eberspächer Swingfire Heater , used in Unimogs and similar Trucks.
Works with Gasoline and produces 11KW , i got one of these to heat my garage if it gets to cold.
Just needs a batterie to start, then it works on its own !
They even sell on US-Ebay !!
FJ40-GARAGE is offline   Reply With Quote
Old 12-25-03, 09:45 PM   #22
hammerhead's Avatar
hammerhead
Re:Garage heat
For less than 8 bucks worth of fuel (including chainsaw) I scored enough firewood to keep the shop warm for a couple months. Only took about 6 hours and gave me an excuse to wheel around out there while I was at it. Found a killer batch of waterfalls to crawl up in the bottom of one of the washes. Cheap and fun. That's what I call efficient garage heat.
Old 01-04-04, 09:07 PM   #23
Junk's Avatar
Re:Garage heat
[quote author=Junk link=board=14;threadid=7948;start=msg78150#msg7815 0 date=1071888519]
[/quote]
Pic and/or pic Woody so I know what you're talking about. I got a small budget for this, for my 24x26 garage but the need is increasing every day. Thanks.
Old 01-05-04, 06:31 PM   #24
Poser's Avatar
TLCA# 1856
Re:Garage heat
[quote author=Junk link=board=14;threadid=7948;start=msg84671#msg8467 1 date=1073275659]
[/quote]
Here ya go...
http://www.gas-space-heater.com/modine-hot-dawg.html
Old 01-05-04, 07:49 PM   #25
OlympiaFJ60's Avatar
OlympiaFJ60 is an unknown quantity at this point
Garage heat
I like the waste oil route. Thinking of getting on from Northerntool.com http://www.northerntool.com/webapp/w...6&categoryId=0 Cheaper than others I have seen and enough heat for a small shop or garage. Best of all it gets rid of the excess waste oil, not just motor oil but gear and tranny oils too.
Also some cheap, do-it-yourself kits or plans.
Brandon
Olympia, WA
http://journeytoforever.org/biofuel_...earth/me4.html
http://www.heco.net/Wasteoil.htm
OlympiaFJ60 is offline   Reply With Quote
Old 01-05-04, 08:31 PM   #26
Ramblin Wreck
CruisinGA's Avatar
CruisinGA is an unknown quantity at this point
Re:Garage heat
I've got 1020 watts of light in a 1.5 car garage.
I hate working in the dark. I don't use my heater, all I have to do is close it up and turn all the lights on.
CruisinGA is offline   Reply With Quote
Old 01-06-04, 07:31 AM   #27
Junk's Avatar
Re:Garage heat
[quote author=CruisinGA link=board=14;threadid=7948;start=msg85238#msg8523 8 date=1073359899]
[/quote]
Uh, dude, you're like in GA, all you would need is the heat from a 1 watt bulb.
Old 01-07-04, 02:28 AM   #28
hammerhead's Avatar
hammerhead
Re:Garage heat
...or light off a fart...
Old 01-07
