What do you guys think about this MIG welder?
http://www.harborfreight.com/cpi/cta...emnumber=55247
I have dime sized holes in the side of my tub from left from a mounting bracket. Instead of Bondo I was thinking of welding in new steel to fix it permanently. How would you go about fixing this? Would you 1. Just bondo. 2. Weld a plate of steel across the back and fill remaining gap with bondo. 3. Weld a new piece of steel inside the then grind/sand it flat on both sides. Small holes so #3 may be tricky. If any of you welding gods (or goddesses) have some tips let me know. I need serious help. Thanks, George |
Plug weld them, that's what I did with my Lincoln SP-135 Mig
later Ryan |
cut the holes out square, weld a piece in, grind flat and thin as possible body filler.
__________________ "In our family, there was no clear line between religion and fly fishing..." Norman Maclean, A River Runs Through It 72' 40 and 92' 80 TLCA #18000 |
Not a very strong swimmer
If your going to buy a welder, I would spend the money and get one that accepts gas.
I don't know how fussy you are, but fluxcore/gasless welders are for farm machinery in my opinion. But, yes I would weld the hole, paper thin layer of filler. Matt __________________ Wanted to buy: FJ45LV interior door handles and door jam stops. If you have any or know of any, please PM me. Thanks, Matt |
The ONLY way to fix it properly is to cut out the complete rusted area, and weld in new metal. If you don't cut out all the rust, or just bondo over it, it'll be coming back. Be sure when you weld in the new metal to treat the backside of it or it will too rust. I have a Millermatic 175 that I love (though I had to leave it at home 500 miles away when I moved down to Texas). It's great for body work like this, but it can also handle welding up thick metal. I would really suggest getting a gas-shielded welder as opposed to flux core. Like Buck said, flux core is meant for thicker metal. It tends to weld hotter, but therefore does have it's place for good penetration in thick metal and of course if you weld in a windy area also.
flux core sucks for body work! I tried on a few different vehicles and lately upgraded to gas and can't believe how easier it is! I can weld thin japanese sheet metal (suzuki!) with no problems with blow out.
__________________ no cruiser right now
total rice
bubble gum. what a DFQ.
__________________ 1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000 2007 4 Runner SR5 4WD - stone stock daily driver ![]() 2007 Avalon - free company Grandpa car TLCA#10793 My ROTW: http://tinyurl.com/2mfwfw |
#8 | |
However.. I need to weld thicker steel than just sheet metal and I also have an Arcone TIG welder (ebay) but I tried this one a few days ago and I liked it a lot weld up to 1/4" I just bought the 220v 180 amps version the quality is great As far as your repair goes I would cut the holes a little larger make a paper template of the hole or hold a piece of steel in the back and spray paint it from the outside so that you have a template, cut, drill a small hole enough to fit a small nail or rivet (to hold the patch as you weld it) or use a magnet, make sure you have a nice thight fit, tack weld all around it very slowly and have a small body hammer handy to tap it back to shape in case you get it too hot , keep tacking unitil you have filled all the gaps, grind etc... easier done than said __________________ "if you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on tv telling you how to do your shit, then you deserve it" - Frank Zappa |
Poldo,
Would you recommend I use gas for my repair or flux core wire? Here is what I need to fix... http://users.adelphia.net/~gcarion/lcpics/holes.jpg Thanks! |
#10 | |
easier to see the puddle the flux creates smoke .. not a big deal but it's there flux cored wire has the big advantage of enable you to weld outdoors in any conditions also does better over paint and rust , that doesn't mean you don't need to clean it up :-) If you are getting a MIG welder get one than can do both, you don't want to be stuck with flux alone, get the best you can afford as you will find more and more jobs to do. The Clarke is the best deal I could find around, also the Harbor freight is not bad just limited by the output amperage, the Clarke is definitely a machine that is built to last and 130 amps are good for steel up to 1/4". The wire feeding mechanism is very nice. The holes are kind of small, you can try and fill them rather than cutting and welding a new piece of metal. Grind them clean and if you can find a thick 3/16"- 1/4" copper plate or aluminum use it to back up the holes and just fill them with short spot welds starting from the edge then grind them flush, the steel will not stick to the copper. Another method is using a steel washer and a rivet, hold the steel washer with the rivet pulling against the backside of the hole, tack weld it , drop the rivet and finish it by spot welding... take your time or the steel will deform and end up looking like cacca
__________________ "if you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on tv telling you how to do your shit, then you deserve it" - Frank Zappa Last edited by poldo; 06-06-05 at 07:51 PM. |
#11 |
Poldo,
Thanks for the great advice! You've really helped me out here. George |
#12 | |
#13 |
KC6ZWY
I agree, gas MIG welding is the way to go. I think, on the other hand, that the welder from Harbor Freight will be fine for what you want to do. I would back the hole with a piece of copper (backing plates are sold at Eastwood Company) that will keep the weld in the middle of the break and on top rather than just burning through.
__________________ Doug Olympia WA 1977 FJ40 1968 R60/2 W/Steib S350 1970 T125 1984 R100ST |
#14 |
I have a Chicago Electric MIG Welder from Harbor frieght (I'm assuming that's what you're looking at cause the link said item not available).
I've used mine a considerable amount and loaned it to anyone who will fill the tank. The only issue I've had is availability of replacement parts. If you have a lincoln or miller any local store can hook you up with a new gun. Harbor frieght doesn't carry parts - you have to special order them. __________________ '97 LX450 - locked, Mickey Thompson MTZ 315's, J's, Rancho RS9000XL 14" shocks, RSC remote shock control 3" front drop brackets, 1" body lift, FOR custom front bumper, and a plethoria of rock lights Owner fabed rotating slider steps, rear bumper / winch and hitch, front and rear extended shock mounts, front spring spacers 1.375", front swaybar drops, rear bumpstop drops, rear swaybar extensions - 'If I can fab it, I won't buy it!' |
#15 | |
15/32 ID-2 1/2 long I just got a clarke 180 amps 220v I love it the wire feed motor and the roller and all of it is very "professional" the gun is a tweco style made by parweld, steel liner etc.. the machine is made in Italy and it is of very high quality for the price And even though they rate it for 1/4" .....I put a hole in a 1/4" plate with 0.35 solid wire so it makes me think their "ratings" are only rough estimates I am still keeping the Harbor freight because it's a 115v and it is good to have it around.. now I am off to weld my wheel wells ![]() PS Parweld also makes tregaskiss style guns that can fit the HF welder much better than the original cheap gun __________________ "if you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on tv telling you how to do your shit, then you deserve it" - Frank Zappa |
Mobile Phones | Remortgages | Myspace Layouts | Remortgages | Secured Loans |
