Old 05-11-05, 03:55 PM   #1
80s muncher
2badfjs's Avatar
can you mig weld DOM tube........
or do you have to tig it???
SOLID ROCK OFF-ROAD
http://www.solidrockoff-road.com/
1991-92 80 series sliders available, WITH CAT PROTECTION!
It's how YOU want it, i'm just here to build it for you.
SLIDERS FOR 40s' 60s' and 80s' plus a little bit more
2badfjs is offline   Reply With Quote
Old 05-11-05, 04:04 PM   #2
Admin
woody's Avatar
TLCA# 1548
My cage is Mig'd...and well tested....go for it!
Brian 'woody' Swearingen
Old 05-11-05, 04:34 PM   #3
80s muncher
2badfjs's Avatar
grassyass
again woody
SOLID ROCK OFF-ROAD
Old 05-11-05, 06:30 PM   #4
Wise One
Texican's Avatar
your thinkin' chrome moly which has to be TIG'd
Butch
_______________
Conflict is inevitable.....
Combat is optional....
Lone Star Land Cruisers
REAL TEXAS MUSIC
Texican is offline   Reply With Quote
Old 05-11-05, 08:04 PM   #5
flintknapper's Avatar
DOM will "mig" just fine. "tig" will make a stronger weld, but may not be necessary for your application. If a "roll cage" is what you have in mind be sure to "gusset" it generously....and you'll be O.K.
Flintknapper:
'97 Land Cruiser, Moonglow Pearl
Chocolate Lab (Kota), I miss you.
ΜOΛΩΝ ΛΑΒΕ (come and take them)
flintknapper is offline   Reply With Quote
Old 05-12-05, 08:08 AM   #6
80s muncher
2badfjs's Avatar
thank you all
very much
SOLID ROCK OFF-ROAD
Old 05-12-05, 08:48 AM   #7
TLCA# 7948
why?
So long as both have proper penetration wouldn't their strength be equal? Wouldn't the advantages of TIG simply be heat control and visual appearance? I would think an experienced weldor (i.e. not me ) could create an equally strong MIG weld.
Not trying to argue, just interested in more details.
fj40Matt is offline   Reply With Quote
Old 05-12-05, 03:47 PM   #8
Originally Posted by fj40Matt
why?
Google "TIG & "MIG" for your answer.
Flintknapper:
Old 06-06-05, 08:08 PM   #9
poldo's Avatar
why?
Tig is always stronger but this doesn't mean MIG isn't strong enough...yes you can MIG weld DOM tubing , Ducati and other high end Bike manufacturers
use MIG on some frames and TIG on others mostly for appearance reasons ..
"if you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on tv telling you how to do your shit, then you deserve it" - Frank Zappa
poldo is offline   Reply With Quote
Old 06-06-05, 08:23 PM   #10
IH8MUD Lifer - No Appeal
Mike S's Avatar
Jim, I can't MIG weld DOM tubing - or much of anything, in fact. You probably can, tho.'
M
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 06-07-05, 08:30 AM   #11
80s muncher
2badfjs's Avatar
thanx mike
M
i always thought DOM was a tig only thing,but in fact i was getting crome moly mixed up with DOM.
thanx all!!!!
SOLID ROCK OFF-ROAD
Old 06-09-05, 07:47 AM   #12
71-CRUISER's Avatar
TLCA# 14378
Wht cant you MIG Cromoly?
Michael Harness
co-owner
www.AtlantaCustomCreations.com
TLCA #14378
03 Tundra 4x4
71 FJ-40 EFI 5.0, NP435, SOA, 38.5s SXs, Disked/Longed/Aussie/4X4 Labs front, welded rear, MetalTech, Saginaw etc.....
71-CRUISER is offline   Reply With Quote
Old 06-09-05, 12:56 PM   #13
80s muncher
2badfjs's Avatar
thats just what i've heard
SOLID ROCK OFF-ROAD
Old 06-09-05, 06:57 PM   #14
honk's Avatar
Tig done right is much less likely to result in a contamination of the joint welded. It's cleaner in other words.
I'm not positive about this but I think the reason for the chrome-moly restriction comes from the requirements of some racing association's equipment rules specifying chrome moly tubing Tig welded for roll cages as well as tubular chassis. You CAN make chrome moly stick together using Mig, stick, or even carbon arc as far as I know, but they may not give you a strong part.
Specialization is for insects
'77 BJ40 FST;'77 FJ40; '65 FJ40;
honk is offline   Reply With Quote
Old 06-09-05, 09:26 PM   #15
4130 can me migged just fine and doubt heat treat will be an issue due to material thickness (thinness).
good ole e70s-3 or e80s-2 for more strength
whats the e70s-3 good for 70,000 lbs yeild ? Any welding process is going to weaken the parent metals, destructive testing is about the only way to ensure your weld procedures are the right ones.
Tigs cool and all , but it is not inherently superior to any other welding process, just another option.
Some of these 'rules' are brought over as Honk stated from racing affiliations and their rules...this tig vs. mig thing comes up alot. But something not mentioned much is their restrictions on the NUMBER of bends on any given tube...
Different environments differing requirements for what is good enough I guess
Late 75 fj-40
Planet_X is offline   Reply With Quote
Old 06-10-05, 03:17 AM   #16
4130 can be sucessfully Migged or Tigged as has been mentioned. In fact (if you know what you're doing) you can O/A with an E70S-6, but most people cant get the flame right.
For anything critical (racing cages) I would "Tig" because it allows the best control of heat, penetration, less contamination, changes physical properties of the parent metal less.
4130 can be migged well enough also, but the chance of building up material without deep penetration is greater. This is where the skill of welder comes into play.
Either way if you Mig or Tig....make sure your material is very, very, clean.
Flintknapper:
Old 06-10-05, 08:00 AM   #17
I sniped your quote flintknapper.
When one is welding on stuff .120 wall and thinner, and the biggest reason to use 4130 is to go thinner wall to save weight yet retain strength, lack of penetration wont be the issue. Melt through will be.
Late 75 fj-40
Old 06-10-05, 08:40 AM   #18
A good argument for "Tig" here. Overpentration (melt through) is not desireable either. With "Tig" you can back off on your foot pedal or hand control. Mig...you'd have to back down on amperage, or ...(hit it, let cool a second, hit it, let cool......) not ideal.
Proper fittment of joints is critical as well....especially "saddles".
Flintknapper:
Credit Cards | Car & Auto Insurance Directory | Online Advertising | Mortgages | Debt Loans
