Old 02-28-05, 12:03 PM   #1
milesstarkey's Avatar
what to use to cut metal
i just got a welder, i cannot afford a plasma cutter. and i'm not going to become a master metal fabricator overnight. a jigsaw will go through blades real fast. a torch doesn't make a neat cut. what do you guys use? for body metal and for 1/4", like for boxing in the frame and stuff.
milesstarkey is offline   Reply With Quote
Old 02-28-05, 12:12 PM   #2
Pin_Head's Avatar
1. Sheet metal: Jig saw with bimetal 24 tooth blade. Or pneumatic nibbler. Or cut off wheel in pneumatic die grinder.
2. Shapes, like tube and square tube: Abrasive cut off wheel.
3. Plate: OA torch (yes, you can make a neat cut with practice) or a sawsall with bimetal blade for 1/4 inch and less. Keep the blade oiled.
Pin_Head is offline   Reply With Quote
Old 02-28-05, 12:13 PM   #3
all options are limited by $. A hand held band saw is great for lots of stuff, but is limited by the depth of cut, also a cold saw ( saw with a circular blade that cuts the steel not burns it away abraisivly) is a good way to go, but also limited by size of the blade, sears sells a grinder specialy fitted with two counter rotating blades that works as a cold saw. I havent used one of these, but the idea is great, the problem with cold saws is they spin at low rpm so they tend to catch and jerk alot if not used stationary with a vise. so by having two blades spining oposite directions it smooths out the operation. also a cutoff disk in a 4.5" grinder is pretty common. If your buying a grinder, the best one is the dewalt paddle switch. Much safer, because it wont stay on if you drop it after you cut your self because you werent wearing gloves. In fact I think all the on/off switch ones should be illegal.
There is also a "nibler" tool that works great for sheet metal, but is limited to very thin material... works kinda like sheers. Beyond these a sawzall can be very handy, and if you use a slower blade speed the blades will last much longer because they dont over heat.
HTH
jetboy,
75-40
Jetboy is online now   Reply With Quote
Old 02-28-05, 12:13 PM   #4
Admin
woody's Avatar
TLCA# 1548
jig saw and metal bandsaw
Brian 'woody' Swearingen
Old 02-28-05, 12:14 PM   #5
Chase77's Avatar
My booty fab tool combo includes a Jig Saw, Chop saw, Circular saw w/ cutoff blade, angle grinder, cut off wheels, & sawzall for when the shit hits the fan. I actually use the Jigsaw the most out of any tool when I did my bodywork. Blades arent really an issue if you know how to use the saw with the proper blades.
89 62 Ironmans, Arb, 33" Procomps
92 4Runner OME'd, Locked F/R, 33" BFG's, ARB/M8000
77 FJ 40 project
Chase77 is offline   Reply With Quote
Old 02-28-05, 12:26 PM   #6
1) torches can make clean cuts.
2) jig saws & sawzalls have their uses.
3) skil saws w/abrasive blade can be handy.
4) Jilson tin snips have some advantages
5) Aviation tin snips work for some things
6) Evolution (like a skil saw) type metal cutting saws would be nice.
7) Horizontal bandsaws shine on tubing
8) Chop saws have been in use for some time
9) Carbide tipped low rpm chop saws are replacing some abrasive cutting
10) Hi-tension hacksaws are cheap
11) Dremels for the tool impaired
12) small hand grinders w/cutting wheels are can do unusual cuts
13) Air or electric die grinders do what #12 & # 11 do, but faster
There are more, but this may help spur ideas.
Invest in some good eye/ear protection for most of these cutting tools- $$ wasted at the ER is $$ that wont go toward Landcruiser stuff.
Planet_X is offline   Reply With Quote
Old 02-28-05, 12:32 PM   #7
Admin
woody's Avatar
TLCA# 1548
worth repeating....a cutoff blade in a hand grinder shattered on me 7 years ago, butterflied my nostrils and left nice grooves in my safety glasses....without those, I'd be split like a watermelon....I have a face shield now for "odd" cuts and have about 20 pairs of safety glasses scattered thru the shop so they are convenient.
60 stitches in your nose sucks.
Old 02-28-05, 07:13 PM   #8
Dont know if you fella's know about these, but they are quality so here's the link fwiw.http://www.envirosafetyproducts.com/html/Paulson.htm
Old 02-28-05, 08:04 PM   #9
Junk's Avatar
I've seen guys cut cleaner with a torch than I can with plasma, so don't say it can't be done. Plasma cutters are one of the most overrated tools out there.
Definitely always keep safety in mind.
Junk is offline   Reply With Quote
Old 02-28-05, 09:14 PM   #10
Former Wheeler
Gumby's Avatar
TLCA# 5658
You can make some nice cuts with a torch and a clean tip. Nice big grinding wheel to make it clean. Plus both those tools have lots of other uses.
A die grinder with lots of cut off wheels would be a good starting place.
I have heard good things about those counter-rotating dual blade circular saws. Supposed to cut through metal like butta.
War Pig and Cerdito
"Don't you know, Stan, it's always between a Giant Douche and a Turd Sandwich."
Gumby is online now   Reply With Quote
Old 03-01-05, 10:07 AM   #11
KC6ZWY
Doug_S's Avatar
I didn't believe it until one of the guys at the machine shop that I was working at did it but...you can cut aluminum rather nicely with a skill saw and a carbide tipped blade. I wouldn't recommend it for steel since you cannot control the blade speed which is important.
Invest in one of the small horizontal/vertical bandsaws that harbor freight sells. They will work under most circumstances and the replacement blades are cheap. I do must of my cutting with a horizontal/vertical bandsaw as do many shops.
Check out the link:
http://www.harborfreight.com/cpi/cta...emnumber=37151
Happy Cutting!
Doug
Olympia WA
1977 FJ40
1968 R60/2 W/Steib S350
1970 T125
1984 R100ST
Doug_S is offline   Reply With Quote
Old 03-01-05, 10:13 AM   #12
I'll say it again...the Milwaukee bi-metal sawzall blades called "The Torch" are amazing. They cut nice smooth lines quickly and last longer than any other sawzall blade even when cutting thick metal. Try them...you'll like 'em.
There are also some metal cutting single blade circular saws out there made by a Czech or German company for about $250-400 at welding shops. I think John Deere also has there badge on one. They make superb cuts and some models even cut bevels and have laser guidance but the blades are pricey ~$50+
For tubing I use a cheap JET bandsaw on a floor stand with a bi-metal blade. It is definitely not the fastest cutting machine out there but the cuts are almost perfect and the price was right. ~$250.00 and blades are about $ 9-12.
For starters though I would get a sawzall with "the Torch" blades and a grinder...prefereably 2 grinders so you have one with a wire wheel and one with a grinding wheel.
Good Luck!
------96-FZJ80 the snowchasing, gear hauling mountain machine--------
-----Now Accepting donations for a true Toyota Diesel Conversion!-----
snowcruiser is offline   Reply With Quote
Old 03-02-05, 01:17 PM   #13
Something clever
Arya Ebrahimi's Avatar
My cutting tools include the following:
Milwaukee 4.5" Angle Grinder w/ grinding wheels, cut-off wheels, knotted wire wheel(invaluable for cleaning up rust/paint/slag/etc), and sand paper wheels(I usually use these without a backing plate, which enables them to conform to odd shapes very nicely)
Oxy/Act torch
$25 Circular saw from a yard sale w/ a 7" abrasive cut-off wheel(poor man's chop saw, and much more versatile)
Milwaukee Sawzall
Milwaukee Portaband(whenever I can borrow it from work)
I second the eye protection comment. It's something I slack on and really need to work on. I wear prescription lenses and they have their fair share of scratches and nicks from flying objects.
Most of these tools are new and I did my entire buildup on my old Jeep with a 4.5" angle grinder and the circular saw. I also agree w/ the ability for a torch to make a nice clean cut. With a clean 00 tip I can cut 3/8's like a hot knife through butter. Just gotta watch the kerf and keep your speed consistent.
Ary
HOKIES UNITED
Arya Ebrahimi
'94 FZJ80 200k miles, locked, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
My mini-truck buildup thread...updated 9/10
Mini-truck's first trip!! With PICS! 11/10
Arya Ebrahimi is offline   Reply With Quote
Old 03-05-05, 06:00 PM   #14
honk's Avatar
One important note:
Don't buy Chinese (et al) made abrasive cutting/sanding blades or wheels or anything. They haven't figured out how to make abrasives!
I'm not commenting on the tools themselves - that's been hashed and hashed again. I've tried grinding disks, cutoff wheels, grinding wheels, drill bits, milling and lathe cutters, you name it because I sometimes a lot of those things and the saving would be significant. But their cutters either don't cut, or they don't last, or both.
Whatever tool you chose to use buy only topnotch cutters for it.
BTW, on a good day I can cut with a torch so's you'd think it was done with a saw. Just takes good people to work with and practice. And attention span. They don't teach it in books very well.
Specialization is for insects
'77 BJ40 FST;'77 FJ40; '65 FJ40;
honk is offline   Reply With Quote
Old 03-05-05, 08:16 PM   #15
GCLC President
cruiserhead's Avatar
TLCA# 15185
"You can cut as straight of a line as you can hold.No matter what tool you use.How is your patience?Any thing can be cleaned up whith a grinder." cruiserhead 3/5/05
1971-80 FJ40 Hey,I used what I had.Trail and plow truck.
1978 FJ40 under construction-soon to get a 3FE
`93 Chevy 1500 Suburban family hauler, wifes DD,`05 GMC 2500HD SLE Extra Cab 4x4 Cruiser Hauler,`95 Kawasaki Vulcan 1500
www.gclcny.com
Installer of Metal Tech products
Crum`s Custom Welding,LLC ccw1@optonline.net
Bumpers to roll cages,FJ40 skid plates-fits stock 3,4 speed & Orion trans and transfer case combos.1 year in development and Telico tested
cruiserhead is offline   Reply With Quote
Old 03-09-05, 04:11 PM   #16
Pytbool's Avatar
I'll second buying good abrasives for cutting. HD and Lowe's sell junk that doesn't last. Buy cutoff and grinding wheels from a welding supply or industrial supply like Mcmaster Carr. You get what you pay for!
I'm partial to the torch since it is handy for heating as well as cutting and has a relatively unlimited cutting capacity for what we do. Cuts get sharper with practice and can always be cleaned up by your grinder.
I have a Milwaukee chop saw, but I'm not real fond off it. Noisy, blade flexes, and sometimes sounds like its going to stall when it shouldn't. My next big purchase will be a band saw.
-Tyler
Pytbool is offline   Reply With Quote
Old 03-21-05, 11:56 PM   #17
1FE pig's Avatar
TLCA# 15226
14" dewalt chop saw.I get blades from the railroad service crew to small for there saw.Nice blades for cutting track.Gas ax is good to.
Big man Pig man
Ha ha charade you are
1FE pig is offline   Reply With Quote
Old 03-22-05, 07:15 AM   #18
Niner's Avatar
TLCA# 13372
Buy what you can afford, patient, and creative. You can do it, just find scrap and practice. Just about all of the tools listed has a strong point but they are only as good as the operator.
Chris Hannis, TLCA #13372
2008 FJ Cruiser, Bud Built 5, Warn Bull Bar, 9.5TI, OME Heavies all around.
1971 FJ 40, 400 SBC, th400, Dana 20 Tcase, F/R Dana 44's, Front 4 link, rear spring over
1993 4 Runner (the Girlfriends) Stock for sale.
A bunch of stuff thats for sale
Niner is offline   Reply With Quote
Old 04-01-05, 09:58 PM   #19
VETTE60's Avatar
i agree with snowcruiser, if you want one tool, get a sawzall it will do just about anything. also for sheetmetal up to 1/4" i use my circ saw with an abraisive blade.
'84 FJ60 TPI 350 NV4500 SPRUNG 4.88's ARB's 37'S 30 spline Longs toy box... built not bought
'03 dodge cummins oil burner crew cab kid hauler...bought not built
FDNY in memory. RFB 343
"Let no man's ghost return to say his training let him down"
VETTE60 is offline   Reply With Quote
Old 04-03-05, 12:31 PM   #20
Never used plasma, but on sheet metal my new favourite fool is a air shears, they cut nice with no noise or dust and do not deform the metal.
I now believe as Junk does that a torch can do as nice of work as the plasma, only difference might be consumables and the cool to touch splama ability.
Check out our new location in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - all hardware included
Limited Quantities - Deposit or Full Payment Required to hold your order while they ship
Old 04-03-05, 01:24 PM   #21
BigRed87's Avatar
Location: THE Texas Tech U. (North Dallas for the summer though)
Chicago Electric has a plasma cutter for $500 from Harbor Freight.
'87 FJ60, 350 to H42, BDS, 33x1250 Yokos, smitty builts, Alpine/RF sound system, extreme shackles, Hella headlights & 500s. you know, that old chestnut.
BigRed87 is offline   Reply With Quote
Old 04-03-05, 06:42 PM   #22
lowenbrau's Avatar
TLCA# 5513
I rarely use the chopsaw since we bought a bandsaw, I don't use the bandsaw as much since we bought ( a real ) plasma cutter. The most versitile tool is for the $ is still the mini grinder with 5" zip discs. We go through boxes of them and they are worth every penny. There are only a couple of brands that are worth spending your money on. The most notable is Walter. Even if they are 3X the cost of lesser disk they are still worth the $. We have a Milwaukee portaband that comes in really handy as well.
There's two sawzall type tools in the shop and only the cordless one gets used and then rarely.
I occasionally use the air chisel with the sheetmetal cutter in it.
These are some brand names you should look for in consumables.
Grinding, cutting, flappy disks.... Walter
Hacksaw, bandsaw blades... Lennox
Sanding products... 3M
Rocky Mountain Land Cruiser Association TLCA # 5513
'87BJ74, '86BJ70, '78FJ45, '53M100, '90M101cdn
I support our Troopies
lowenbrau is offline   Reply With Quote
Old 04-03-05, 06:51 PM   #23
lowenbrau's Avatar
TLCA# 5513
Don't be mislead. Plasma ain't cheap to run. Tips are $5 and electrodes are $25. When the plasma and air compressor are running they are drawing 35 Amps at 460V. You never really count the cost of electricity though do you? The good news is you rarely run out of electricity at midnight in a Saturday night like I always seem to with the Oxy/ Acetelene
Old 06-06-05, 08:45 PM   #24
poldo's Avatar
Sorry disagree the oxy/ace torch will overheat the sheet metal and warping it
for body bork nothing beats a plasma however you can't use a plasma alone
in the shop.
Also plama cutters are cheaper to run .. no gas to buy
"if you wind up with a boring, miserable life because you listened to your mom, your dad, your teacher, your priest, or some guy on tv telling you how to do your shit, then you deserve it" - Frank Zappa
poldo is offline   Reply With Quote
