Old 02-20-05, 10:14 PM   #1
Not enough hot water
I am puzzled. I have a 15 years old water heater (Natural gas). About 6 month ago or maybe a bit longer it started giving me some head aches. Even 1 person cannot take a shower for more then 10 - 15 minutes. I set the thermostat almost at HOT and still the same issue. Drained and checked for sediment, no problem. Well today, went to Lowes and picked up a 40 Gallon Whirlpool Water heater. A friend of mine came to help me. And again the same problem, my son took a shower, about 10-15 minutes and there is NO MORE HOT water.
Any ideas, comments, where the problem might be?
Thanks,
Alex
85 BJ70
93 FZJ80
bj70alex is offline   Reply With Quote
Old 02-20-05, 10:15 PM   #2
Junk's Avatar
Did you take the water restrictor (name?) out of the shower head by any chance?
Junk is offline   Reply With Quote
Old 02-20-05, 10:21 PM   #3
DUM8HIT
T Y L E R's Avatar
Check for a bad element .. or thermostat .
Also run over to your panel and look for a tripped breaker .
TY
Hybrid suspension - Slee 4" Front/OME863 Rear, Slee Front control arms, Slee DIY adjustable panhards, Slee sliders, 36X13.5R16 IROK radials on AR Black Trenches, 1.5" Trail-Gear spacers, Toughbook CF74 with GPS etc, sans roofrack, jumpseats, lockers. Clear lenses abound
T Y L E R is offline   Reply With Quote
Old 02-20-05, 10:32 PM   #4
Tyler,
It's a brand new 40 Gallon Whirlpool Natural gas water heater. Can it be a bad thermostat or bad element?
Alex
85 BJ70
93 FZJ80
Old 02-20-05, 10:36 PM   #5
offroadkid's Avatar
TLCA# 12427
Shorter showers!! I got mine down to 7 minutes!!
Joshua
1998 UZJ100 Imp. Jade Mica/Gray 295 Nitto TG's
“Some dream in color, I dream in 4 wheel drive."
My Wife's AVM story
www.findchristiewilson.com
offroadkid is offline   Reply With Quote
Old 02-20-05, 10:40 PM   #6
DUM8HIT
T Y L E R's Avatar
Originally Posted by bj70alex
Tyler,
Alex
85 BJ70
93 FZJ80
Just throwing out a few options .
Breaker ok ? Maybe run the shower and stand next to the box listening ...
TY - no expert sorry
Old 02-20-05, 10:58 PM   #7
offroadkid's Avatar
TLCA# 12427
Here's an online forum I found while looking for a solution to your problem. HTH!! I remembe once my Dad telling me that Whirlpool has a troubleshooting guide on their webpage, but I looked and did not see anything for "hot water heaters."
Joshua
My Wife's AVM story
Old 02-20-05, 11:39 PM   #8
Ih8mud stalker
mabrodis's Avatar
Hmm...well it all comes down to how much water you're using. Is your shower dumping out alot of water? If you have the hot water heater set as hot as it'll go (adjustment on the actual unit), and you're still running out, then the hot water heater isn't heating well (i.e. some are 35K btu, some are 40K btu), and/or the water coming into the heater is really cold. If you're getting water from a well it's probably very cold, so the heater has alot of work to do...only way around it is....well nothing.. Take shorter showers, or put in a low-flow high mist (hehe, can't call it water, just a shower mist) nozzle
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." -William Arthur Ward
'96 4runner, 3.4L, 5sp, E-locker...
'85 Mini, 2nd owner...add-ons: 31" MTRs, oil & dirt stains...
'00 Echo, 1.5L of FURY!
mabrodis is offline   Reply With Quote
Old 02-21-05, 12:59 AM   #9
IH8MUD No-Lifer
hoser's Avatar
Check for a hot water leak. Turn off all your faucets and showers and take a look at your water meter. Perhaps its running?
98 LX470
85 BJ70
hoser is offline   Reply With Quote
Old 02-21-05, 03:17 AM   #10
calamaridog's Avatar
Hot water heater will supply xx gallons of hot water then takes forever to heat up the next batch. If your kid takes a "hot" shower, then it will use it faster. Bump the thermostat up a little and less hot water is needed to warm the cold water...
And just how HOT of a shower is the kid taking anyways? I had a 10 minute limit when I was a kid...
Also, were there any other appliances using the hot water at the same time? No way your getting enough hot water for shower, dishes, and laundry at the same time.
I replaced my 40 gallon with a new 40 gallon as a precaution because the old one was 20 years old. No difference in performance:(
The best systems are the "on demand" water heaters which do not have a tank. They actually use less energy because they don't store the water. The problem is that an on demand heater which will run multiple applications cost in excess of $1000+ for the equipment.
Hopefully there is a plumber who can settle this one
2000 UZJ100 - OME - sold Currently looking for the right FJ60
TLCA #14734
Calamaridog
calamaridog is offline   Reply With Quote
Old 02-21-05, 05:23 AM   #11
PabloCruise's Avatar
TLCA# 10713
You turning your hot water on ALL the way when you shower?
Sounds like volume to me...
When I shower, I just barely turn the hot on, then just enough cold to get the temp right. I can shower practically all day. My wife on the other hand turns the hot on much more, then much more cold to get temp right. I prefer to shower BEFORE she does.
If you do have a really cold water source, you could put a holding tank in next to the hot water heater - let the water get to room temp before heating. Course, then your heater will have to work harder to heat that room!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 02-21-05, 10:15 AM   #12
IH8MUD No-Lifer
hoser's Avatar
Alex, all relatively new shower heads restrict flow to 2.5 GPM and an older type or modified head will flow at 4-5 GPM. At 5 GPM, you can go through all your hot water in less than 12 minutes. If you don't have it already, maybe it's time to change to the 2.5 GPM heads.
The more important factor to look for in water heaters is not capacity but "first hour recovery rate." A 30 Gallon water with a high recovery rate can perform better than a 40-50 Gallon model with a low recovery rate.
I just installed a 75 Gallon high recovery rate water heater for a two person household. This is for my new shower with 2 shower heads and 3 body jets. I also prefer the larger heater so that I can run it at near its lowest heat setting.
98 LX470
85 BJ70
Old 02-21-05, 10:22 AM   #13
The problem you had with the old heater could occur if the cold water dip tube were to have fallen to the bottom of the tank. If that happens, then the cold incoming water directly mixes with the hot water at the top of the tank and does not get properly heated during periods of extended use.
That would not explain why you are having a problem with the new heater. Double check to be sure that the hot and cold supply lines are not backwards. If they were, that would cause the same problem as a dropped or missing dip tube.
Rich is offline   Reply With Quote
Old 02-21-05, 11:41 AM   #14
informationjunky's Avatar
TLCA# 6149
Any type of anti-scald valve past the heater that could be failing?
Georgia Cruisers
Upstate Cruisers
http://www.upstatecruisers.net/
TLCA 6149
86 FJ60 - first and RIP
95 FZJ 80 - second RIP
97 LX 450 - Current
locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor
98 LX 470 - wifes
informationjunky is offline   Reply With Quote
Old 02-21-05, 12:45 PM   #15
fj40crusher's Avatar
TLCA# 11862
When I built my house I had 2 water heaters installed.
I live with 2 teenage girls, a woman and a 3 year old. Laundry, dishwasher and tub pretty much run around the clock.
My plan worked perfectly.
I have two guns, one for each of you
TLCA#11862
74 FJ40 M-416 trailer, 85 FJ-60, 97 FZJ80-ce (locked and loaded)
2006 Tundra quad cab 4x4
Countdown till she's 18------24 months!
FUCK YOU SPRINT!
fj40crusher is offline   Reply With Quote
Old 02-21-05, 12:59 PM   #16
Talking
It's not a "Hot Water Heater" it's a "WATER HEATER"!!!!
First off, I'm not claiming to be an expert here. I do however do engineered plumbing design and use quite a bit of commercial equipment to heat buildings, water, etc.
The first ? I have is where are you located??? From the looks of your handle, your from the north???
The second, describe the location and surroundings of your heater. You may have placed something that is obstructing the air flow to the burner assembly, thereby reducing the GPH of hot water. Also do a flue check as well.
Also check the flow to your heater on the CW side.
Some things to keep in mind. The higher temp you keep your heater, the shorter life it will have. This is esp true with gas fired tank type heaters. Recovery has nothing to do with the gallon size of the heater, only the energy input. Tanks should be drained and cleaned on a yearly basis. This is very true for those of you that are supplied with well water.
Jford.
jford is offline   Reply With Quote
Old 02-21-05, 12:59 PM   #17
northerner
semlin's Avatar
ok, I will avoid the question of what he is doing in there for 15 minutes. You don't want to know.
It's all about the shower head. We have an old fashioned clawfoot tub with one of those old fashioned 4 inch diameter shower heads that is awesome but a big water user. We used to have a 40 usg tank and now have a 50 us gallon water heater. Even now you can't do 2 long showers back to back. With the old tank you needed to wait 15 minutes for the second shower and it would be curtailed early by cold water. At our old house where we used a water saver shower head we had no problems with 2 showers back to back.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
semlin is offline   Reply With Quote
Old 02-21-05, 02:16 PM   #18
I'm really very humble
photogod's Avatar
If all the above doesn't work call the gas company and have them come and look at your gas meter. They replace the entire unit every 15 to 20 years and if you haven't had this done your diaphram might be kaput. If you are running a lot of gas appliances at once you might be putting to much stress on the old meter and diaphram. we had ours replaced 20 years ago and when they put in our new streets the gas co came through the neighborhood and replaced all of them again.
photogod is offline   Reply With Quote
Old 02-21-05, 02:30 PM   #19
I m m o d e r a t o r
Jman's Avatar
You want hot water? Post up that you've sold your BJ70 to Mushro.
87 FJ60
Banks are for suckahs!
Originally Posted by wob View Post
F**k you Jman, you cycloptic bastard.
Originally Posted by yooper View Post
NO NO NO!
Jman is wrong. I bet a beer that he's wrong.
Jman is offline   Reply With Quote
Old 02-21-05, 03:03 PM   #20
Trunk Monkey's Avatar
TLCA# 11251
Nuther thing to check would be the valve in the tub. If you've got one of those tubs that has one handle for hot/cold, if the valve goes bad it can leak cold water into the hot water flow, making it seem like you don't have hot water.
Cory Fillmore
TLCA Western Individual Representative
99 UZJ
100 Series Wheels FOR SALE-CLICK HERE
Trunk Monkey is online now   Reply With Quote
Old 02-21-05, 06:27 PM   #21
80 series Addict
FJ809496TLC's Avatar
TLCA# 15498
Not enough infos.. Some possibilities: faulty mixing valve, not enough gas pressure coming out of the meter, restricted hot water flow or the water heater is just not big enough.
NRA Life Member 100 Club Life Member 94 96 96 97 all locked. Still looking for locked and stock Maroon, Blue or an Antique Sage 40th Anniversary Edition in pristine condition in and around Houston. On hold for now. Building a new house put a big hole in my pocket.
FJ809496TLC is offline   Reply With Quote
Old 02-21-05, 07:05 PM   #22
not in million fawking years!!!!!!!!!!!! I will sell my BJ70 to Mushro!!!!!!!!
Alex
85 BJ70
93 FZJ80
Old 02-21-05, 07:25 PM   #23
Jford,
"The first ? I have is where are you located??? From the looks of your handle, your from the north???", No I am not from north, I am in south central KY.
We also have gas heat (2 heat pumps) and the problem with hot water (not enough) started happening, would say about 1.5 ago and if the gas company did something that I am not aware of, maybe it has a direct impact on not enough gas needed for water heater. I will check with gas company and post the results.
Water heater is located upstairs, we have a two story house and there is pleanty of ventilation in the small area upstairs (water heater only).
Thanks for great ideas and comments.
Alex
85 BJ70
93 FZJ80
Old 02-22-05, 03:06 PM   #24
Jford,
I called the gas company and sure, they replaced the meter in March of 2004. My question is, what is the purpose of this diaphram? Also, I have two natural gas furnaces, one downstairs and another one upstairs.
Thanks,
Alex
85 BJ70
93 FZJ80
Old 02-22-05, 03:55 PM   #25
My guess is the hot out from the w heater and cold in are reversed.
JB
Throttleman_610 is offline   Reply With Quote
Old 02-22-05, 04:11 PM   #26
80 series Addict
TLCA# 15498
bj70alex, have your gas regulator check also. It might be defective or not adjusted correctly.
Old 02-22-05, 04:40 PM   #27
Cruisin'Carolina's Avatar
Jford.
LMAO!!!
I run into these about 2X week in my line of work.
I worked with a guy that would go ballastic anytime somebody used that phrase.
I'm no plumber, but let me tell you if yours is 10+ years old, get it checked, or just replace it with a more efficient unit. Make sure you have a pan underneath it so when if fails it will catch the water.
USE A BIG TUB! Those 1-2" lip pans do a horrible job of keeping up when 40 gallons come rushing at it....(Rust through, or pop-off pressure valve "relieves" itself. Make sure the drain line isn't clogged either. )
"I hate conservatives, but I really f*cking hate liberals" Matt Stone
94 FZJ80.....ARB, OME, Revo'd, Eclipsed and Locked.
86 FJ60: Sold!
Cruisin'Carolina is offline   Reply With Quote
Old 02-22-05, 08:30 PM   #28
photogod's Avatar
Jford,
Thanks,
Alex
85 BJ70
93 FZJ80
The purpose of the diaphram is to regulate the pressure of the incomming gas. If you have two furnaces, 2 water heaters, gas dryer, gas stove and oven, gas garrage heater you should let the gas co know as you are overtaxing the "normal" gas use. We had mostly electric appliances when we moved in and when we put in our gass appliances it did the same thing to us that is happening to you. The diaphram will not let enough gas(low pressure) into the line to feed all the equipment you have running. Have the gas co come ouy and take a look at what appliances you are runnung and they will be able to tell you what the issues are for your application.
