husqvarna 266se, grease?
So I picked up this 266se last fall from a nieghbor that was moving. I got it running today and need to cut down a 30"+ diameter tree tomarrow night. My other two saws are smaller 20" and 18" saws, but this one has a 30" bar on it. It's been a few years, 15, since I used my fathers big old husky while clearing land outside boston for our house. The neighbor gave me a bunch of misc. stuff with the saw, including a grease gun with a needle tip on it. Given the fact that he gave it to me with the saw I figure I need to use it somewhere on the saw. Where do you add grease to this thing? Gas, bar oil.. I got all that, just need to know where to put the grease.
__________________ Trent Taylor 76 fj40, sm420, 4wdb, 35 muds,bikini made out of a trampolin. 93 80 w/270k, fading green paint, flareless, 255 muds, home built front bumper, and a load whine that wont go away. 97 40th Sage w/lockers--Bone stock |
Ability follows Interest
Take a look under the clutch coiver at the center of the clutch (end of the crank) there may be a hole there to get grease into the clutch bearing.
also the nose sprocket of the bar, if it is a sprocket tip, this can be omitted as it is lubed pretty well by the bar oil. __________________ 1988 FJ62 on 33s 1996 LX450 on 33s I sincerely believe that banking establishments are more dangerous than standing armies, and that the principle of spending money to be paid by posterity, under the name of funding, is but swindling futurity on a large scale. Thomas Jefferson |
If it has a roller tip on the bar you need to grease those before use.. or about every hour.
__________________ IF IT HAS TITS OR TIRES YOU'RE GONNA HAVE TROUBLE WITH IT !! -ROSEBUD 5_9_6- |
Yep. There is a small hole on the end of the bar. Grease it till it's spilling out the bar grooves.
__________________ 1984 FJ60---Hi-perf 2F with other goodies 1978 Hilux---Dirty old man truck1994 Honda XR600R 2003 Polaris RMK 800 (@)==Toyota==(@) <----- 60's rule! |
Thanks guys. I found the holes on the roller tip and greased it up before I started and every 30 minutes or so during. Nothing like limbing a big tree while it was snowing and windy. I did that with my trustworthy old homelite 18". That thing takes a beating and is probably older than I am. I was lucky to have the 30" husky as the trunk cut was almost 38". Thanks again for the help.
Beagles Rule!
You do not need to grease it every 30 minutes unless the bearing is bad.
Grease the tip when you are done using at the end of the day. __________________ Cruiser Dan at American Toyota Phone is 1-800-432-6668 ext. 8 (I am not cruiser Dan) |
I figured 30 minutes was way overkill, but I don't think the saw had been used in years. I figured it wasn't going to hurt anything. I'll keep all greasing under control, thanks.
Cheap Loan | Loans | Zappos Coupons | McDonalds | Loans |
