UC VP & Cook
Blast cabinet window.
I know there has to be a trick to keeping the window clear when blasting. I'm tired of buying these laminates that go over them. They get frosted fast.
Could I just put a piece of glass or something in there? __________________ Marshall UC VP & Token Club Cook Greenville, SC Big Gay 2f Build The Great Cruiser Part Links Thread Buying a Land Cruiser Guide "On second thought, let's go to Chat. It is a great place." 73 Fj55 Big Ugly 76 FJ40 ROTW 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
No brag..just fact
Naw,
The glass will frost just like the plastic. I Use clear packageing tape. Have to replace it quite a bit. Just try not to aim the nozzel at the sight window much! Good luck...
__________________ 77 '40 desmogged stock DD 78 '40 play toy with all the good shit 95 F-250 (when the tojos dont run) 02 Polaris 500ho deep wood transportion |
Rookie with a torch.
I took a welding class at the local community college. They used saran wrap over the glass. Worked pretty well and didn't impare vision that badly.
He was a pretty busy instructor so it was a sloppily applied. If a guy had a little time I wonder if he might be able to wet it and squeege it on like vinyl to last longer. Or even a couple layers. Andy __________________ 1973 FJ40 - So far: V8, SM465, Scout PS, SR, SOA, 55 springs, 4WDB, Painless, Revolvers, 37's, Still to come: Cage, ARBs, Orion |
If you figure it out, let me know. I just change out the glass whenever I can't see through it anymore. It costs about $5 to change out the glass.
take a piece of plastic window screen and build a small frame to go around it that is about an inch thick. This will hold the screen about an inch to an inch away from the glass and stop a lot of the beads from getting in there.
Leave the bottom of the frame open for beads to get out. Also a good idea to hook up an air only gun in there to blow stuff off in the cabinet and blow the dust off the screen. I hooked up my shop vac to the cabinet and then ran a house out the wall of the wall in the shop to blow what ever dust that runs through the vac outside via a dryer vent. I also find that using a large cabinet with tempered glass makes it last a lot longer than a $3.00 piece of glass from home depot. I was able to get pieces for about 20 bucks each from the local glass guy. Smaller cabinets seem to get a lot of media blasting around inside. With a large cabinet, you can hold the work at arms length and direct the spray down into the hopper. I built a huge cabinet that is large enough for motor cycle frames, 5x5x3. The same piece of tempered glass lasted several years with a screen in front of it. The air only blow gun is ideal for unclogging the suction feed line too. -JS |
#6 | |
UC VP & Cook
Hmmm. I wonder if stretch wrap would work. Saran wrap is a good idea as well as tempered glass. __________________ Marshall UC VP & Token Club Cook Greenville, SC Big Gay 2f Build The Great Cruiser Part Links Thread Buying a Land Cruiser Guide "On second thought, let's go to Chat. It is a great place." 73 Fj55 Big Ugly 76 FJ40 ROTW 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
I've used clear mylar in the past with good results. That way you can set it up like a helmet tear-off. Plus it's not difficult to find it on the cheap.
__________________ 1994 80 - Some stuff Tornado Alley Cruisers - TAC Those who can, do; those who can't, criticize. |
Mortgages | New York Hotels | Credit Card | Remortgages | Problem Mortgage |
