Old 03-09-08, 01:41 PM   #1
EricG's Avatar
EricG is on a distinguished road
Stihl Chainsaw not oiling?
Ok, I may have gotten ripped off on Craigslist ... surprise surprise
I bought a used Stihl MS310 for $200. Met the guy at a parking lot in town to make schedule work, reduce driving et. Stihl saws don't last long on CL so I wanted to jump on it.
It started up great, then I aimed it at a patch of snow to check the oiler - no oil So I said something to the guy and he says maybe it's empty. Now when I run a chainsaw, if there's gas in it, there's oil in it - no question. You never fill one tank without filling the other. But a quick look in the tank confirms it's bone dry despite > 1/2 tank of gas.
So ... I bought it anyway, hoping it's probably just empty and $200 is a good deal for what looks to be a relatively new & lightly used saw.
Bring it home, add oil, aim the bar at a log ... still nothing significant. Occasional spatters of really black stuff, not the spray of fresh oil I'm used to seeing from my POS HD Poulan.
My guess is the seller new the oiler wasn't working, so he drained the tank. No oil? "Oops, must be empty - sorry". The guy was on his way to his job selling cars - considering what I know of car salesmen, it wouldn't surprise me
So - any suggestions where to start? I'll be taking a look at the manual tonight.
It is neither necessary or possible to educate someone who never questions anything. - Josephe Heller, Catch 22
93 FZJ80 - Locked & Lifted - still waiting on Loaded (CDL, 7pin, Axle transplant from Jenny Cruiser, 2" OME lift)
EricG is offline   Reply With Quote
Old 03-09-08, 02:02 PM   #2
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
D'Animal is on a distinguished road
There is a drive gear behind you clutch. Take you side cover and bar and chain off. Remove the e-clip holding the sprocket drum on and remove the drum. Make sure the chain brake is disengaged. On the back side lip of the drum you will see a notch. Look on the outside of the clutch and you shoul see what looks liek a little wire. That little wire fits into the notch of the sproket drum. If the tip of the wire is broke off or worn off it will not drive the oil pump. No biggie to repair.
My Tow Rig = http://forum.ih8mud.com/hardcore-cor...g-tow-rig.html
D'Animal is online now   Reply With Quote
Old 03-09-08, 02:52 PM   #3
EricG's Avatar
Ok, thanks! I'll take a look.
Old 03-09-08, 04:44 PM   #4
You want to do what...?
e9999's Avatar
e9999 is an unknown quantity at this point
if you have Dan working with ya on anything related to saws, you're golden!
I also make a point of making sure that the hole in the bar that directs the oil into the groove is not plugged.
'97: 86K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!)
'03: 97K, the better half's...
DD
Old 03-09-08, 08:33 PM   #5
TLCA# 16841
Jimmy B is on a distinguished road
To thick of oil can sometimes affect the oilers performance also
91 HZJ73 warn electric winch,electric lockers,suspension seats
Jimmy B is offline   Reply With Quote
Old 03-09-08, 11:04 PM   #6
EricG's Avatar
Yea, that is one concern - the oil I dumped in seemed thicker then usual. Hadn't used that brand before, and it was relatively cold. But the chain has to have oil, cold or not!
Anyway, I didn't get to it tonight.
Thanks guys.
Old 03-10-08, 11:03 AM   #7
tntoyota is on a distinguished road
did you check the oiler for debris?
then run a very thin oil through it? (rev and shake the tar out of it)
it works a whole lot better with the bar out of the way.
then check the oil pump, and I dont know exactly how but I know you can adjust the flow.
try that, if you adjust it and get the oil flow going, more than likely it will oil too much, then slowly back it down to match the tank
I should be a rep for STIHL!
tntoyota is offline   Reply With Quote
Old 03-10-08, 06:52 PM   #8
TLCA# 16841
Thanks guys.
I have gallons of the summer stuff at work and just thin it out for the winter with a little 10w engine oil or even the 2 cycle oil works for thinning( not the mixed fuel,just the oil)
Old 03-10-08, 10:45 PM   #9
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Summer weight oil is a base 30w and winter is a base 20w.
Running summer weight oil in the winter puts extra stress on the oil drive gear and will wear it out prematurely.
The oiler drive gear is the one I mentioned in my above post. The wire clip is connected to the oiler drive gear and the other end is engaged in the backside of the drum. The oiler only turns when the clutch is engaged and the drive sprocket is turning. Not all saws are this way but you is. The oiler drive gear is the designed weak link in the system. If it breaks, wears out, etc it is less than $10.00. No damage to the pump itself or the cutting attachment (bar and chain)
There is a screen in your oil tank that you should probably check. It is a black plastic piece about the size of a 9mm bullet. It is stuck on the end of the hose. It comes off with needle nose pliers.
The clutch comes off to the right. DO NOT USE AN IMPACT WRENCH! You can shear the flywheel key if you do.
Old 03-10-08, 11:21 PM   #10
Dave-T's Avatar
TLCA# 16951
Dave-T is on a distinguished road
Yep. Take the spark plug out and cram something clean (I use starter cord, easy to get back out) into the combustion chamber to limit the pistons motion so you can take the clutch off.
I also clean the oil passages out all the way to the tank. As mentioned above be sure and clean out the holes in the bar and also the entire bar grooves. If your oiler is adjustable turn it all of the way up, just keep an eye on the tank. On a cold morning let the saw run for a bit before cutting. It will heat up the oil and make it flow better.
1984 FJ60---Hi-perf 2F with other goodies
1978 Hilux---Dirty old man truck
1994 XR600---Street legal
(@)==Toyota==(@) <----- 60's rule!
Dave-T is offline   Reply With Quote
Old 04-01-08, 11:25 AM   #11
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Well?
Old 04-01-08, 04:43 PM   #12
EricG's Avatar
Well?
To damn busy - hoping to get a look at it this weekend.
Old 04-03-08, 05:17 AM   #13
the guy you ignore
Spud's Avatar
TLCA# 8675309
Spud is on a distinguished road
Yes, as someone else mentioned, the flow rate is adjustable for the oil. Could be as simple as that.
Keep going,
Sam
"Is it being prepared to do the right thing, whatever the cost. Isn't that what makes a man?"
"Sure, that and a pair of testicles."
84' 4runner (work truck)
Nov / 76' FJ40 (work/fun truck)
80' Jeep J-20 Dump and Boom
Spud is offline   Reply With Quote
Old 04-23-08, 10:40 PM   #14
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Well?
Well how did it work out?
It's getting too darn close to wheeling season for you to start using it.
Old 04-25-08, 05:12 AM   #15
the guy you ignore
Spud's Avatar
TLCA# 8675309
I think he forgot he needed to use the saw???
Keep going,
Sam
Old 06-10-08, 05:34 PM   #16
EricG's Avatar
Well, I finally got at it tonight - gotta get some beetle kill trees down before they fly :(
Much warmer weather now, so I decided to try it again - the oil was very thick when I added it previously. Started right up and revved it - nothing/very little for a while, then some blobs of thick grease-like stuff flew out. Then it started oiling at what seems to be a respectable rate - though not as much as my old HD Poulan seems to do. Any tips on determining if it's pushing enough out? Since it appears to be all crapped up in there, I wonder if running a little kerosene through the oiler might help?
Old 06-11-08, 09:48 PM   #17
Dave-T's Avatar
TLCA# 16951
Do not run something like kerosene through it, that could damage the oil pump. Did you perform all the things listed above? Like cleaning the bar, checking the oil pump, and turning up the oil?
A few ways to know if it's oiling enough. Place the tip of the bar close to pavement or a piece of wood etc and throttle up the saw. You should see a defined discoloration (oil being thrown off the chain) withing a few seconds. When cutting is the chain getting hot and burn marks on it? Also, when the saw is out of fuel there should be about 1/2 to 1/4 left in the bar oil tank.
Old 06-12-08, 09:41 AM   #18
EricG's Avatar
Well, after running it a bit more and seeing how much was being sprayed off, I decided it was probably OK and started cutting. I kept a close eye on the chain for overheating, but it worked fine! I took down two ponderosas - one about 16" diameter at the base, and the other probabaly about 20" at the base - the saw worked beautifully! Much better then the old Poulan. Where I would have to really work to get the poulan through those logs - overheating & dulling the chain in the process - the Stihl just walked through it! I may keep the poulan around for a backup/limbing saw, just because it's so light and I probably won't get squat for it if I try to sell it anyway.
Thanks guys
Old 06-23-08, 12:26 PM   #19
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
The flow rate is 8 – 18 cm3 at 10,000 rpm. With the oil pump adjusted to the minum setting it will be 8 cm3 at 10,000 rpm and in the full open position it will be 18 cm3 at 10,000 rpm.
A good quality bar and chain lube will not spray off the tip of the bar. You need the lube on the bottom of the bar since that is where you are cutting and the majority of the heat build up.
Old 06-23-08, 02:25 PM   #20
EricG's Avatar
Ok - is there a rule-of-thumb for chain oiling that doesn't involve this level of test equipment?
Interesting - that's how I've always checked for oiling. So if I'm getting some spray it either means I've got crappy lube, or I'm over-oiling. The latter shouldn't be a problem other then a messier saw - as long as I don't go through a tank of oil in less time then I go through one of gas.
Old 06-23-08, 02:29 PM   #21
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
LOL!
Most people use a rain gauge that has the cc's on it as well as inches. They use a small funnel as well.
Take your bar and chain off and hold it over the funnel in raingauge. rund the saw about 3/4 RPM and see how much oil you get.
If it is oiling fine right now and you are happy with it then just run it.
Old 06-23-08, 03:18 PM   #22
EricG's Avatar
LOL!
Ok, cool - I was envisioning some kind of rube goldbergian contraption involving a timing light, alarm clock and a squirrel on an exercise wheel but wasn't sure if a gray, red or black squirrel was appropriate or where to get a wheel big enough
Maybe I'll have a go at the much simpler rain gauge test when I have some time (don't hold your breath).
Old 06-23-08, 04:44 PM   #23
carboncycles is on a distinguished road
For clarify, this is cm^3 per MINUTE? I am guess that is correct with the 10k rpm, but I thought I'd be clear.
TIA
carboncycles is offline   Reply With Quote
Old 06-23-08, 06:46 PM   #24
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
TIA
Yep, per minute. Each model of STIHL has it own flow rate range.
The best way to tell is if you have 15% to 20% of the oil left in the tank when you are out of gas. All saws are designed this way.
This will fluctuate when you rip with the saw of if you use a saw mill attachment.
