How to cut threads with die...
... and keep the die square? A tap centers itself if the ID is correct for the size of the tap but how do you get a die to stay centered? I've tried cutting threads on round stock and after an inch its clear that the die is cutting at an angle. Eventually the die jams as it cuts more and more towards the center of the round stock. Any tricks?
__________________ Joel '89 FJ-62 |
#2 | |
__________________ 69 FJ40 with some minor mods... 2000 Cummins powered Dodge with some power enhancements. DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business! http://www.paypalsucks.com |
Unfortunately I neither have one or know how to use one (although I always like to learn to use new tools
). Do you have a pointer to more info on this?
You want to do what...?
doesn't your die holder have a centering jig built-in?
__________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD and souped up DR650 |
No brag..just fact
You will need a sleeve a couple of thousands larger than the rod your threading. Make sure it has a square shoulder and place the die up against this shoulder. You will have to hold the die tight against the sleeve for about 3 or 4 turns until the die has a "set" on the rod or bar your threading. You will also need to keep the die soaked in cutting fluid or a good oil. You can use old motor oil if that is all you have. This is not that hard to do, but it does take some practice. Good luck....
__________________ 77 '40 desmogged stock DD 78 '40 play toy with all the good shit 95 F-250 (when the tojos dont run) 02 Polaris 500ho deep wood transportion |
It does but either I'm using it wrong or it doesn't work very well. Plus there is 3/8-1/2" before it kicks in which seems to be enough to let it get off to a bad start...
#7 | |
What I have done the the past is drill(drill press is best) a hole a tad bigger than the tap you will be using on a piece of stock that's a half an inch thick but perferrable an inch thick. Take that knewly drilled piece, clamp it down directly above the hole that will be tapped. This even works on something that is flat as well.
#9 | |
UC VP & Cook
Do you have it backwards? I always have the centering part on the unthreaded portion. __________________ Marshall UC VP & Token Club Cook Greenville, SC Big Gay 2f Build The Great Cruiser Part Links Thread Buying a Land Cruiser Guide "On second thought, let's go to Chat. It is a great place." 73 Fj55 Big Ugly 76 FJ40 ROTW 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
#10 | |
flip it around? __________________ '97: 88K, 3xlock, Custom HD roo bar for sale, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!) '03: 99K, the better half's... DD and souped up DR650 |
#11 |
No brag..just fact
Well Hell, I forgot a very important item to keeping a die square. You should put a heavy champher on the ( starting) edge of your rod or dowel. 30-45 degrees works good. And it needs to be champherd to the depth of the threads bottom. Look at a bolt and you will see what I mean!
Sorry (I'm getting old) __________________ 77 '40 desmogged stock DD 78 '40 play toy with all the good shit 95 F-250 (when the tojos dont run) 02 Polaris 500ho deep wood transportion |
#12 | |
No brag..just fact
Loans | Credit Counseling | Car Finance | Vietnamese Magazine | Credit Counseling |
