Old 01-29-08, 08:22 PM   #1
Tunnelratt's Avatar
TLCA# 17080
Looky What I hauled home today
I am doing a bit of freelance consulting work for a company that is going to do a small 10/11 million cu/yd grading job, there was an old mining operation on the site as well as structures dating back to the late 40's and there was power up until today in a shop on the site.
I have been wanting a compressor and tank large enough to run all of my air tools without having to wait to catch up, here it is! It's going to the sandblaster this week, fresh coat of paint, check out the compressor, wire up the motor and away we go.
I couldnt get info of the data plate and without doing the math yet, it appears to be 100+ gallons, built in 1958, speedaire compressor and a late model 220# electric motor, and the best part, you ought to see the frigging whistle that was rigged off the tank, I guess it was used as a signal device, the neighbors are gonna LOVE me!
OH, and it was free, just had to disconnect and load from a covered pit about 6' below grade.
Cant wait to use it!
"Non Gratum Anus Rodentum"
75 FJ40 FST Doing the slow build
Steve
Tunnelratt is offline   Reply With Quote
Old 01-29-08, 09:02 PM   #2
Capt. Jim's Avatar
TLCA# 5390
You sure you want to pressurize that 50 year old tank? All the prep/paint on the exterior will do nothing for the years of interior moisture, rust/corrosion that may be in it.
If ya think that whistle is loud, wait to you hear a 100 gallon tank loaded to 200 psi let loose.
My advice, don't use it.
Capt. Jim
Florida Land Cruiser Association
North Florida Cruiserheads
Upstate Cruisers
TLCA #5390
Capt. Jim is online now   Reply With Quote
Old 01-29-08, 09:09 PM   #3
fj40charles's Avatar
X2.. Might be good for making a BBQ grill....
69 FJ40 with some minor mods...
2000 Cummins powered Dodge with some power enhancements.
DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business!
http://www.paypalsucks.com
fj40charles is offline   Reply With Quote
Old 01-30-08, 05:24 AM   #4
wfd175's Avatar
X2 on a hydrostatic test prior to use. X3 on the bbq.
1980 40
1996 80
2 kids, a wife and a dog.
wfd175 is offline   Reply With Quote
Old 01-30-08, 06:55 AM   #5
Welcome to palace
Hugh Heifer's Avatar
TLCA# 17468
Yep, get it hydroed and visualed like you would a scuba tank before pumping it up.
Hugh Heifer
9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders
[ And a '71 going ground up]
FJ60 PARTS THREAD CLICK HERE!
Originally Posted by Hugh Heifer View Post
VOTE HUGH HEIFER
He sucks less
Hugh Heifer is offline   Reply With Quote
Old 01-30-08, 07:09 AM   #6
-Spike-'s Avatar
Speedaire is good stuff, but that compressor looks undersized for the tank. It probably isn't intended to do more than 125 PSI. That's not to say it won't crank the tank to 500 PSI given a big enough motor. I too would be nervous about the age of the tank, but maybe not as nervous as other folks. Not a bad idea to have it checked if that's possible. Make sure the safety valve(s) work too.
-Spike
His 1994 TLC 'White Elephant' +6"/35" Locked and loaded.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is offline   Reply With Quote
Old 01-30-08, 05:36 PM   #7
KLF
KLF's Avatar
There is NO WAY I would use that tank. That much volume at 100+ psi stores a LOT of energy, and if it lets go, it's gonna take your whole garage with it.
And that compressor is waaaaay too small.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 01-30-08, 08:28 PM   #8
Tunnelratt's Avatar
TLCA# 17080
Chickens! Yeah, It had occured to me that tank is almost as old as me, and even though it was pressurized when I pulled it, I dont think my old hull would hold 200 psi either, for very long, took it to the sandblaster today, he quoted me $200 +-, I said Thanks, it's not worth spending $200 for a clean paint job, I am going to price a Hydro test, it may prove futile to try to use it...Oh well, at least I got a Frigging cool ass brass whistle
Steve
Old 01-30-08, 08:37 PM   #9
Cuerno Largo's Avatar
TLCA# 16073
Make a smoker out of it if you don't use it as your compressor. Nice find. Nothing like free. If it passes pressure test then Jasco it and put rustoleum on.
'75 FJ-40-In pieces on my garage floor. -Buildup thread here
'07 Titanium FJC- wife's ride
My statement to my wife: "All of the accumulated crap in my shop will be really useful if I find a use for it."
"You may all go to Hell and I will go to Texas"- Davy Crockett
Cuerno Largo is offline   Reply With Quote
Old 01-31-08, 03:15 PM   #10
Tunnelratt's Avatar
TLCA# 17080
UPDATE! As I dont have a way to look inside the thing I figured I would do some exploratory hammering, so I flipped the tank on it's back and proceeded to hit what should be the approximate flow line in the bottom of the tank, to see if there was indeed any serious rust from the inside, all seemed pretty OK until I hit the bung where the fluid drain is, or should I say, WAS, I knocked a hole in the bottom the size of a silver dollar.
Oh well, at least I didnt spend any cash on the thing or blow a hole in my garage.
So I loaded it back up and hauled it where I got it, I guess I will just spend the dough and get what I want
Steve
Old 01-31-08, 03:20 PM   #11
what he said
Mace's Avatar
Smoker dude...
Say it with me..
The motor and compressor might be worth somethigng as well..
I am kinda gay.......
My Myspace
Old 01-31-08, 03:22 PM   #12
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Why didn't you make a Bar B Que out of it?
D'Animal is online now   Reply With Quote
Old 01-31-08, 05:29 PM   #13
Tunnelratt's Avatar
TLCA# 17080
The closest I ever got to a smoker was one of those little electric aluminum box set ups, Dad had one and he would smoke the pheasant and chucker, I would have no idea how to even go about it.....I should have asked if anybody wanted the thing.
Hell, does anybody want it? I could go back and get it I suppose, then figure out how to get it moved around.
Oh, and I did keep the motor and compressor
Steve
Old 01-31-08, 05:57 PM   #14
BooKilla's Avatar
TLCA# 18193
Are you close to palm desert? If so, I'll take it for a smokin' BBQ pit.
The Boone
'85 4runner (sold)
'91 FJ80 (3fe powa)
'94 FZJ80 (lockered)
'98 4runner (sold)
"Buying parts I don't need, with money I don't have, to impress people I don't know."
Co-Founder of the Lake Oswego Militia
BooKilla is offline   Reply With Quote
Old 01-31-08, 06:07 PM   #15
Tunnelratt's Avatar
TLCA# 17080
Nah, 3-4 hour ride, right now no plans to head south from SCV
Steve
Old 02-02-08, 05:42 AM   #16
sk8salomon's Avatar
is there an info plate on the tank? most tanks are required to have some sort of max psi rating on them. i spoke to an engineer once about the safety factor built into them and he said 30%.
Running total of non-waving FJC drivers ......534
'85 FJ60 bone stock (the way i like it)
'87 Ford Ocnorb with lots of redneck stuff & custom dented body panels
sk8salomon is offline   Reply With Quote
Duelmasters | Hotels | Mortgage | MPAA | Loans
