Old 01-28-08, 11:47 AM   #1
latinoguy's Avatar
Cutting Metal & Welding Question
I ordered a set of sliders from Adam at 4xinnovations for my 80 series, and plan to make them bolt on, using George's specs to fabricate the face plates...(Actually a local fabricator will do most if not all of the cutting & welding work...I will just assist him)
The questions I have are:
1. Is a 2 3/8" face plate big enough to weld a round tube outrigger measuring 1 3/4? Or is more extra surface area required?
2. Having a cordless 18V reciprocating saw, I can get a head start and cut the face plates myself....(3/16" thick plates) If This a viable tool to cut this thick of metal....or am I better off buying a chop saw? (The other option is to have my fabricator use his plasma) I am just trying to get as much involved as I can...and save some $$$
Hope I was clear
James
97 FZJ80, "La Mula" DD, ARB, Tire Carrier, Sliders, OME 850J/863 springs, L shocks, 295/75/R16, Slee TC Skid Plate, Rear Storage, CB, LEDs, SS Brake Lines, Rear work lights, GPS, HIRs Highs&Lows "Beauty is in the eye of the beer holder."
latinoguy is offline   Reply With Quote
Old 01-28-08, 01:00 PM   #2
BooKilla's Avatar
TLCA# 18193
How thick is the plate? .25/.35/.5?
1) How are you going to put bolts large enough through the corners of that small of a plate? Use a plate that is the size of section of frame you are mounting it to. Then make sure you truss the plate and tube together. That will stiffen it up quite a bit.
2) Absolutely not. The only real way to cut thick metal is with a plasma cutter or an o/a torch. For really precise cuts you'll want to use the plasma; for really thick metal or hardened metal you are going to want to use an oxy torch.
If you are having a fabricator do the work, he should absolutely have an o/a torch and probably should have a plasma.
The Boone
'85 4runner (sold)
'91 FJ80 (3fe powa)
'94 FZJ80 (lockered)
'98 4runner (sold)
"Buying parts I don't need, with money I don't have, to impress people I don't know."
Co-Founder of the Lake Oswego Militia
BooKilla is online now   Reply With Quote
Old 01-28-08, 01:05 PM   #3
KI6MIE
Cruiserdrew's Avatar
TLCA# 11734
I'd use a bigger plate.
You can cut up to 1/4 inch accurately and well with an angle grinder. You get grinding dust everywhere, but it works great.
You will not be happy trying to cut real metal with a Sawz-all.
Andrew
1997 FZJ-80 Driveway queen
Cruiserdrew is online now   Reply With Quote
Old 01-28-08, 01:53 PM   #4
latinoguy's Avatar
Let me clarify: 1. The narrowest Face plates are 2 3/8" Using 3/16" thick metal...They are obviously taller in size to allow for attaching the U-bolts...
Yes-the fabricator has a plasma cutter...you answered my questions. Thank you!
James
Old 01-28-08, 02:22 PM   #5
Atoyot1031's Avatar
TLCA# 18402
Hope I was clear
Did he make up a custom set for ya? I measured my angles (with a bevel gauge) and cut them all myself. I purchased one of the Porter Cable dry-cutting carbide tipped chop saws off ebay for <$300 to the door! Well worth it, in what it allows me to do...
Good Luck!!!
Atoyot1031 is offline   Reply With Quote
Old 01-28-08, 03:06 PM   #6
latinoguy's Avatar
Nick, Yes he did....He made them a bit longer... 72" in lenght...getting everything else I need.
U-bolts, metal, and waiting for the sliders...
James
Old 01-28-08, 07:27 PM   #7
Junk's Avatar
If he knows you want to be involved and learn some then ask him if you can try cutting the material at his place with the plasma. Hey - it can't hurt to ask and chances are if he's a good dude that he'll let you try it.
Junk is offline   Reply With Quote
Old 01-30-08, 07:51 PM   #8
Capt. Jim's Avatar
TLCA# 5390
Are you going to u-bolt the mounting plates to the frame? If so, it kinda defeats the purpose of the slider as some of the plate must be below the frame rail to accept the lower portion of the u-bolt. Or, am I not seeing how you plan to attach correctly???
Capt. Jim
Florida Land Cruiser Association
North Florida Cruiserheads
Upstate Cruisers
TLCA #5390
Capt. Jim is offline   Reply With Quote
Old 02-01-08, 01:30 AM   #9
chappysfj40's Avatar
TLCA# 9188
my 2 cents is dont do any cutting or anything till you are working on the rig putting the sliders on.
cheers
- Iam home now from the SUCK !!!!!!!
VJ60 700R4 33's 203 doubler, ARB's 4.56, OME and just a awesome truck!!!!!!!!!!
- RUBITHON 2008 TESTED
GOD ASKED FOR 10 DAYS TO CREATE EARTH, CHUCK NORRIS GAVE HIM 7..
chappysfj40 is offline   Reply With Quote
Old 02-01-08, 09:04 AM   #10
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
You could use a bandsaw to make your plates. They are about the same price as the chop saw and make a lot less mess.
D'Animal is offline   Reply With Quote
Old 02-01-08, 03:25 PM   #11
fj40charles's Avatar
Less mess, less noise, and better quality of cut. I need to buy one soon, but have not found a good one yet and I don't want to buy a HF special. I'm tired of using my chop saw.
69 FJ40 with some minor mods...
2000 Cummins powered Dodge with some power enhancements.
DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business!
http://www.paypalsucks.com
fj40charles is offline   Reply With Quote
Car insurance | Mortgages | Lincoln LS | Broadband | Car Insurance
