Old 01-24-08, 04:01 PM   #1
TLCA# 13863
Time for a new water heater
The water heater, most probably call it a hot water heater which makes no sense to me, is heading South. I have never installed one much less know anything about them and could use some help.
Pertinent Info.....
Family of 4. Two children under the age of 3. Wife and I plan to buy a new house in two-four years and maybe rent out our current residence. The unit is electric, unfortunately. I don't know how many gallons the current unit holds.
We run the dishwasher 2-3 times a week. Most laundry is done in cold water, sometimes warm.
Questions..
1. How do you determine the volume needed to get the right size?
2. Is there a way to determine the ROI for purchasing a more expensive but energy efficient model?
3. Can a less efficient model be made more efficient by insulating the unit
4. Any tips and tricks for removal and installing a new unit?
When it comes to this stuff I really don't have a clue as to what I'm doing or talking about. So if the info or questions need more clarification, I'll post up what you need.
Thanks,
Buck Buchanan
Toyota 4x4's of Texas aka T4x4T
97 LX450 OME 2.5, 1" spacers, CDL w/pin7, Toyo 315's, cup holder, Bullbar, Hannah Sliders & Rear Bumper.
TLCA# 13863
Buckru is offline   Reply With Quote
Old 01-24-08, 04:32 PM   #2
-Spike-'s Avatar
If what you have worked in terms of size, replace it with similar. 40 gallons is the smallest I would go, preferrably larger. Or, look into an on-demand heater if you want efficiency- not to mention the extra storage space you get without the tank. I did one of those last year and got a tax credit on the full amount of installation. Not cheap though.
Wrapping a new water heater with extra insulation is a waste of time IMO. Feel the outside of the tank. If it's at room temp, extra insulation isn't going to do anything for you.
Installation- empty the old unit. Make sure to disconnect the power before draining. Replace the shutoff valve with a ball valve, and I always plumb with flexible copper lines that have female pipe thread connectors at both ends, similar to garden hose ends with the same type gasket seals. Usually there's a need to solder something during the installation, but if you use these supply lines and also use a threaded shutoff ball valve, there will be no need for a torch the next time you need a new water heater. Or, if you're insanely lucky, the last guy who changed it thought like that.
-Spike
His 1994 TLC 'White Elephant' +6"/35" Locked and loaded.
Hers '95 TLC Bare bones.
"I don't understand this business of illegal aliens giving birth to American citizens. If your cat has kittens in the oven, would you call them biscuits?" -Unknown
-Spike- is offline   Reply With Quote
Old 01-24-08, 05:12 PM   #3
we changed ours last spring, straight forward, just installed another shutoff valve on top. other than that is was a direct bolt-in install. even the gas line was right on.
if installing a replacement....make sure it has the dip tube in it
we looked into ondemand/tankless but for us it wasn't going to work with our well water to good. mineral buildup. bigger gas line install needed also a newer flu to handle the extra exhaust.
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 01-24-08, 07:11 PM   #4
KLF
KLF's Avatar
Wrap that room-temp tank, then slide your hand under the wrap a few days later. I'll be plenty warm in there.
I like putting union fittings on the supply and return lines. A lot easier to pull it out and put the new one in next time. If the lines have gate valves on them, take them off and throw them away, put ball valves on.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 01-24-08, 07:24 PM   #5
MoJ
Present
MoJ's Avatar
TLCA# 14112
For a family of 4 50ga would be the minimum. Building code for new residential construction in my county specifies a min of 50. The purchase cost b/n 40 and 50 is minimal.
MoJ is offline   Reply With Quote
Old 01-24-08, 10:38 PM   #6
TLCA# 13863
Thanks for the help. I'll be giving it a go this weekend.
Buck Buchanan
TLCA# 13863
Old 01-26-08, 03:55 PM   #7
Brewers in '08!
webelk6's Avatar
Tankless
I went with a Noritz tankless water heater. I will never go back to the old style. I also have 4 kids and a wife. We had a 40 gal gas heater, the Noritz is also gas, and the savings is already tremendous.
04/75 fj40 slowly under resto......
build thread http://forum.ih8mud.com/40-55-series-tech/99015-04-75-frame-off.html
'94 FZJ80 (DJ81) with 14k gold emblems(wifes)
'06 Tundra/Work Truck Model Iforce V-8 ( paint/estimating rig)
webelk6 is offline   Reply With Quote
Old 01-27-08, 11:35 AM   #8
How 'bout a beer!
Hugh Heifer's Avatar
TLCA# 17468
I also think this is the way to go. The first time I saw these I lived in Puerto Rico and conventional heaters took a beating in the island. Those tankless "hot water on deman" units are the bomb. They are often significantly more expensive then conventional but IMO well worth it.
Hugh Heifer
9/71 FJ40 / 4 Speed / '77 2F / Weber / Header / 4" Skyjacker / 35" BFG Mudders
[ And a '71 going ground up]
FJ60 PARTS THREAD CLICK HERE!
Originally Posted by Hugh Heifer View Post
VOTE HUGH HEIFER
He sucks less
Hugh Heifer is offline   Reply With Quote
Old 01-27-08, 11:41 AM   #9
beaufort-fj60's Avatar
significantly = 4x as much.. 40 gallon is about 230 clams.. decent tankless is about 1000+ clams, then tag on installation. I was quoted $1600 for a tankless install about two weeks ago. It would of replaced a 40 gallon. If you have the money get a tankless.
Real Americans drink PBR
beaufort-fj60 is offline   Reply With Quote
Old 01-27-08, 11:46 AM   #10
How 'bout a beer!
TLCA# 17468
Wow. Funny they were much cheaper in the Caribbean. I noticed they were more back on the mainland. Even cheaper outside the US (like on St. Martin). I can not vouch for the brand or quality if those, however.
Hugh Heifer
VOTE HUGH HEIFER
He sucks less
Old 02-09-08, 04:50 PM   #11
Toyo FJ40's Avatar
Use the dielectric unions (they sell them at plumbing supplys) they break the elecrical conection between the copper pipes and the steel tank which protect against galvanic corrosion.
Kevin
72, 74 and 78 FJ40s
Toyo FJ40 is offline   Reply With Quote
Old 02-09-08, 07:49 PM   #12
Brewers in '08!
webelk6's Avatar
Noritz has some really nice rebates as well. I know my plumber and got a smokin deal at about $800 installed
build thread http://forum.ih8mud.com/showthread.php?t=99015
Old 02-11-08, 05:27 PM   #13
FJ40_owner's Avatar
TLCA# 16294
Yes but you now have endless hot water. How do you get teenagers out of the shower?
This is the one remaining issue for me prior to going tankless.
Third generation Californian! If you don't like it here, leave. And take your fat wife and screeming kids with you.
FJ40_owner is offline   Reply With Quote
Old 02-11-08, 07:36 PM   #14
Brewers in '08!
webelk6's Avatar
True. However after about a 3 month turn around our gas bill went down $50. To me that is huge. And I am always monitoring the 2 boys, ; Yelling"Hurry up, you have 3 minutes" , about 3 times......
Old 02-13-08, 10:15 AM   #15
GreatBasinCustomHomes.com
haystax's Avatar
TLCA# 14279
FineHomebuilding mag just did a big story on water heaters - they say a savings of about 19% is what you will see from a tankless heater compared to standard however since you never get out of the shower you probably end up using more water and more power than a conventional.
Article suggests a 190,000btu with .82 or better energy factor for your size family -
I'm a little skeptical about full life cycle costs of tankless heaters and wonder if they are really worth the investment. At less than full flow, the heater short cycles and that is never good in any type of machine. You will also be out of hot water during a power outage (assuming you have a pressure tank or utility service) and hard water will eat up a tankless way faster than an anodized tank heater. Sediment also has no where to go and utility lines w/ water hammer can send junk into your tankless that you never knew was there before with a tank model. This is my opinion as a homeowner looking to build new based on a winter's worth of online, magazine research and plumber ?'s - obviously there are people who are happy with them as well but i believe it is too early to tell on a full life-cycle ROI type analysis. A near 100% efficiency tank heater is pretty bulletproof and would probably serve you well in your specific circumstance IMO
I would suggest subscribing to the online magazine for some really good ideas and no-nonsense articles. Especially if you are looking at building or buying a new home in the near future this magazine has been a GREAT resource for me. Good luck
'76 FJ40 - 2F,SO,SR,RDB,PS,4.88,Q78TSL,earlydizzy,mod'd carb,Aussie'd front,weld'd rear,MetalTech'd...still too fast in 4LO
Great Basin Custom Homes
haystax is offline   Reply With Quote
Old 02-13-08, 10:22 AM   #16
FJ40_owner's Avatar
TLCA# 16294
Wow 190K BTU. My old forced air furnace was 150K BTU and was quite noisey. (We could hear it from anywhere in the house.) I suggest noise might be another factor to consider where to locate and install a tankless WH.
When my teenagers move we will purchase one.
Home Power is another very useful magazine that deals with various alternate energy water and space heating systems.
Old 02-13-08, 12:55 PM   #17
AJP
Sorry to hijack the thread a little ... but along the same lines...
I just bought a condensing boiler (very lightly "used") for a radiant floor heating application...have read the associated manuals/literature many times and slowly making sense of how it works ... I am curious if anyone has an opinion on the domestic hot water tanks that use a coil to transfer boiler heat to a DHW storage tank ... I will be using propane and not sure whether a "standalone" propane fired water heater/storage would be better or if the indirect water heater/storage is a better way..
the boiler claims 15,000-150,000btu/hr and 92.6% AFUE, 97% on radiant slab
AJP is offline   Reply With Quote
Old 02-13-08, 01:10 PM   #18
-Spike-'s Avatar
Mine (Paloma, 199,000 BTU) is quiet. The only audible noise comes from the fan that drives the exhaust, no more than a quiet bathroom fan. You can hear the heater come on if you are in the same room or the adjacent bathroom.
-Spike
Old 02-13-08, 02:58 PM   #19
Brewers in '08!
webelk6's Avatar
I appreciate your reseach, but if you check European markets, I think you will find they have been around since the '70's. IMHO I will never go back from tankless. It only runs when you turn on the hot water.
Old 02-13-08, 05:57 PM   #20
haystax's Avatar
TLCA# 14279
I've seen and used tankless heaters in Europe - they usually hang in the shower stall under the showerhead and are handy for storing shampoo bottles. I am not doubting Euro technology as I am using a Buderus mod/con boiler from Germany, Grundfos circ pumps from Denmark, and Uponor PEX and manifolds from Sweden in my heating and domestic hot water system -
I am also not denying any efficiency gains compared to an el cheapo standard tank heater - but many have compared apples to oranges in this thread, and I hope that you are as happy with the heater five years from now
Old 02-13-08, 06:53 PM   #21
Brewers in '08!
webelk6's Avatar
I will keep you posted. my previous standard water heater(sears) lasted 14 years
Old 02-13-08, 07:24 PM   #22
GeoRoss's Avatar
Sediment isn't an issue with a tankless as the water is always moving. There isn't really time for it to settle. And any sediment that does form is flushed through the system at the next usage.
Many tankless do not require electricity. They run off some sort of piezo dodad water wheel thingamajob. So electricity loss of service isn't an issue. Gas loss of issue is a problem for both, but more so for a tankless.
We went with tankless units more for the space savings than energy efficiency. I wish I had ponied up for a Paloma or Rinnai, but went Bosch.
1994 FZJ80, OME850/864 w/ CSC 1.5" spacers, 285/75 r16 BFG AT/KO, 131K
"SUBDUCTION leads to OROGENY"
"Strip Mining Prevents Forest Fires!" "Stop Continental Drift!"
"Tuff Schist" "Reunite Gondwanaland"
GeoRoss is offline   Reply With Quote
Old 02-13-08, 11:20 PM   #23
-Spike-'s Avatar
Why, did you hear something about any of those? I bought the Paloma 'cause it was available and I couldn't find anything negative about the company, but I'd never heard of them before. I like Bosch power tools...
-Spike
