Old 01-13-08, 06:54 PM   #1
Godwin's Avatar
Vertical orientation of hand held drill
Putting together a cargo box for my FJ60 I needed to drill as-near-as possible holes perpendicular to the plywood surface. I did a couple of test holes which came through at unacceptable angles. Not having easy access to a drill press the idea of attaching a post level to the drill came to mind, and it works well enough for what I've been doing. With the plywood lying flat, using the post level on the drill, and carefully watching the pair of individual horizontal levels the holes can be drilled to an acceptable perpendicular degree. I'm using a 14v Milwaukee drill in this case and the post level attaches flatly. I'm sure there will be plenty of other drills which will not work. YMMV, etc.
Just wanted to pass this along in the event someone else may find it useful.
Jim Godwin
1977 FJ40 with some stuff
1985 FJ60 with 3FE
1986 FJ60 now with stuff
1997 FZJ80 stockish
Tallassee, AL
Godwin is online now   Reply With Quote
Old 01-13-08, 08:11 PM   #2
A.K.A. BATMAN
TLCA# 18154
sounds like a pita. you can pickup a drill guide with adjustable hole size and adjustable angle for about 20 bucks at the local hardware store. drills true every time
Adam West
'86 fj60, 2"lfit, 31x10.5MTs, fresh engine, DD
'88 fj62, work in progress, 2FE,
'91 fj80 bone stock s NEW DD
RELAX, HAVE A HOMEBREW
crzrcrzy is offline   Reply With Quote
Direct TV | Loans | Libro infantiles | Fantasy Football | Mortgage Calculator
