Old 01-13-08, 01:17 PM   #1
Ramblin Wreck
CruisinGA's Avatar
Changing 4 conductor dryer to 3 conductor
We got a free dryer from a friend, it is a residential model, but has a 4 conductor plug. Our wall outlet is the standard 30 amp 3 conductor (slant blade).
It should be possible to just install a new 3 conductor plug on the dryer, right? How would I wire it?
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 01-13-08, 06:42 PM   #2
nat
nat's Avatar
Old style 220 is 2 hots and a neutral
new style, is 2 hots, 1 neutral and 1 ground.
If it were me, I would rewire the 3 prong wall outlet to a 4 prong style.
1972 FJ55 "Geirdriful" named after one of the Valkyries
Check out my build thread:
http://forum.ih8mud.com/fj55-iron-pig-preservation-society/165633-build-up-progress-my-piggie.html
Some more good pics of the Pig here too:
http://forum.ih8mud.com/fj55-iron-pi...-iron-pig.html
Maid Marion, "Why, you speak treason!"
Robin Hood, "Fluently."
nat is offline   Reply With Quote
Old 01-13-08, 08:55 PM   #3
e rock's Avatar
TLCA# 6829
Go to the hardware store or appliance store and buy a new 3-prong pigtail - make sure it's long enough for your application (usually 4 or 6 feet) - maybe $15 or so?
On the back of the dryer, pull off the little access panel right above where the cord goes in (5/16" hex). Disconnect the old cord and remove the stain-relief bracket. Insert new cord through the hole and hook up the three wires to the posts. As long as the middle wire goes to the middle post, you're good. Tighten the nuts and install the stain-relief bracket (yes it's important).
*accurate for 95% of dryers out there.
-Eric
64 FJ40, slightly modified.
97 LX450, bone stock.
e rock is offline   Reply With Quote
Old 01-13-08, 11:54 PM   #4
Focus on the Journey
bsevans's Avatar
TLCA# 16217
New dryers have 4 wire to support the electronic controllers in newer dryers.
78 FJ40
ARB's F&R, Rear Disks, DUI HEI, 200 Amp Alt, OME 2.5, 33x10.50, PS, RE8000, Stout Rear Bumper, 4+Plus Sliders/U-Bolt Flip Kit/Tie & Relay Rods/Anti-Inversion Shackles, Dual Tanks, BTB Dash Box, Tuned Ceramic Coated Headers, Extended Axle Vents, BrakeQuip Custom Certified SS Brake & Clutch Flex Lines
ROTW My Yoda|HD Skid Plate|Recovery & Windshield Washer Tanks|Toyota Pulley on GM Pump|Bypass Hose
bsevans is offline   Reply With Quote
Old 01-14-08, 06:07 PM   #5
Don't forget to reinstall the machine's euipment ground bond between the "Middle" post and the machine's frame.
GiantTechGuy is offline   Reply With Quote
Old 01-14-08, 06:09 PM   #6
Overall BEST installation would be to hire an electrician and have him-her install a new 4 wire receptacle.
Old 01-14-08, 06:22 PM   #7
Main reason for the 4 conductors is to isloate the neutral conductor( current carrying) from the machines frame and still "GROUND" the frame. You see old style 3 prong installations can be a shock hazard if you were to contact that frame and be a better path to ground than is the circuit's neutral conductor.
Old 01-14-08, 10:23 PM   #8
Ramblin Wreck
CruisinGA's Avatar
It's an older dryer...
Found the installation manual online, installed a 3 prong pigtail according to the manual... Works great!
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 01-15-08, 05:10 PM   #9
Did you install the machine's euipment ground bond between the "Middle" post and the machine's frame?
Old 01-15-08, 08:57 PM   #10
Ramblin Wreck
CruisinGA's Avatar
Yes.
Thanks.
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 01-18-08, 08:26 AM   #11
Yes.
Thanks.
Great, happy drying
Freelance | Coupon | Bad Credit Mortgages | Debt Consolidation | Power Rangers
