Old 01-21-04, 12:20 PM   #1
Yo_Han's Avatar
Solvent Suggestions....
Hey Juane,
I did the same b4 my rebuilt.... called some local autopart stores and there was a Advanced Auto near me that had 5 gallon barrels of parts cleaning solution, used that and worked great.
Maybe a there's cheaper alternative?? but I would just call around
Yo Han
Yo_Han is offline   Reply With Quote
Old 01-21-04, 08:16 PM   #2
Junk's Avatar
Re:Solvent Suggestions....
Whatever you do, do not use simplesuck(green). It's corrosive, which is something I did not know first time around.
I picked up a heated parts washer a few months back. Guy that sent that it to me included some industrial airplane degreaser they use at airports. It was cheap but worked great. Wish it had a lablel, but if you want I can email the guy and find out what it was.
Junk is offline   Reply With Quote
Old 01-21-04, 08:28 PM   #3
around here we get 5 gallon buckets of Stodard Solvent. works real good, not too pricey, when its fresh, I suggest gloves as it makes the hands a little tingly.
3_puppies is offline   Reply With Quote
Old 01-21-04, 08:45 PM   #4
juane's Avatar
[quote author=Junk link=board=14;threadid=10448;start=msg93744#msg937 44 date=1074741415]
[/quote]
That'd be great, Junk. I'd like to know. thanks
A heated washer?
juane
juane is offline   Reply With Quote
Old 01-21-04, 11:02 PM   #5
hammerhead's Avatar
I go to my local oil distributor that supplies solvent to the local repair shops and buy automotive solvent in 5 or 30 gallon containers. They also have 55s but that's a bit much for my small shop.
hammerhead is offline   Reply With Quote
Old 01-21-04, 11:48 PM   #6
Riley's Avatar
I use Varsol. Comes in 10 gal?? cans and they run about $18.
Very cheap, works pretty well and not too many fumes. Also safe around welders as it won't catch fire.
I don't have a washer, just use my wifes baking pan that's 2" deep.I had to buy her another.
Riley is offline   Reply With Quote
Old 01-22-04, 12:13 AM   #7
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
All the Parts Washers I've used had AVGAS in 'em, Never had a problem with my Hands.
Jonathan_Ferguson is online now   Reply With Quote
Old 01-22-04, 01:16 PM   #8
Parts Shaman (per Romer)
cruiserdan's Avatar
TLCA# 11332
[quote author=Jonathan_Ferguson link=board=14;threadid=10448;start=msg93842#msg938 42 date=1074755583]
[/quote]
I guess you are a non-smoker then?
Old 01-22-04, 05:19 PM   #9
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
[/quote]
Blue 100LL or Purple 130??
AVGAS....HA HA HA!!!
Never had a problem with your hands...sure, how are your offspring?
Stick with Stoddard solvent, and use thick protective gloves, good petrol-based cleaners are carcinogens, and damage the nervous system too..
FUN STUFF-BREATH DEEP!!
Good luck!
-Steve
Old 02-09-04, 10:34 PM   #10
RHINO's Avatar
too funny, kerosene degreases pretty good, but i have had some real good luck with this stuff called workhorse from a janitor supply place. i buy one gallon and dillute it a bit. if you cant find workhorse i was looking at labels and all the janitor degeasers have similar ingredients. oh about $7 a gallon
Old 02-09-04, 11:50 PM   #11
Poser's Avatar
TLCA# 1856
Kerosene does not cut like a good stoddard solvent. I found a fuel supply place here that sells it by the gallon, right out of a fuel pump.
Good stuff.
-Steve
Old 02-12-04, 02:22 PM   #12
Ramblin Wreck
CruisinGA's Avatar
Straight up Mineral Spirits.
Worked great when I did my front axle rebuild.
CruisinGA is offline   Reply With Quote
Old 02-12-04, 04:39 PM   #13
Former Wheeler
Gumby's Avatar
TLCA# 5658
I have heard that Grainger has some good stuff. I have not yet investigated. Safety Kleen sucks. Way too stinkin expensive.
Gumby is online now   Reply With Quote
Old 02-12-04, 05:02 PM   #14
Poser's Avatar
TLCA# 1856
[quote author=Gumby link=board=14;threadid=10448;start=msg104060#msg10 4060 date=1076629192]
[/quote]
Agetine. It is a green solvent. Great stuff.
Kinda spendy...
I like MEK and laquer thinner for those tuff to get clean pieces......Great stuff!!! Let it soak in there for a little while, agitate a bit, and things come out clean as can be...
Old 02-17-04, 06:12 PM   #15
RHINO's Avatar
maybe not, but for just cleaning grease off parts why pay for stoddard?? if you want the axact same thing as stoddard but much less money just use mineral spirits. ok not the exact thing, but as far as grease is concerned its the same flat disc cutting atoms known as benzene.
Old 02-17-04, 08:27 PM   #16
Poser's Avatar
TLCA# 1856
rhino-
All what you wnat to use, and the level that you want to take it too...
I like rinsing everything that is going back together with some sort of solvent that flashed off easy, MEK, 1,1,1,-Trichlorethelen, brake cleaner, etc...
Old 02-17-04, 10:16 PM   #17
RHINO's Avatar
i hear ya, and i agree completely. just pointing out the use of inexpensive solvents for simple grease removal.
i also like to blow off some parts immeditly with compressed air to avoid flash rusting.
Old 02-24-04, 02:57 PM   #18
Jr. Spaceman
Klunky Chris's Avatar
TLCA# 4821
I don't have a parts washer, I use a 5 gal busket
Kerosene works good for me, had to scrub some of the stuff on my knuckles, and it eventually eats the $3 yellow kitchen gloves.
I wash it all down with brake cleaner afterward.
but!
when I'm done I throw the whole mess, used grease and all into the oil tank and burn it in the furnace in the house
re-cycling is goooood
used motor oil goes in there in small amounts also
Klunky Chris is offline   Reply With Quote
Old 03-17-04, 02:18 PM   #19
Benji's Avatar
TLCA# 14119
I came across some spray solvent/lubricator called Deep Creep by Sea Foam. I use it on everything from cleaning parts to keeping the hinges clean and oiled. I works great on air intake and is some of the most multi-functional stuff I have seen. You can get it at O'Reiley's autoparts for $6 a can. Oh yeah, spray it on ordinary metal and it treats it and repels the water. I am a big fan. You guys might look into it.
Not affiliated of course.
Benji is offline   Reply With Quote
Old 01-01-08, 09:18 AM   #20
66fj40x2's Avatar
TLCA# 10749
Has anyone used ProForce HD Degreaser? I found it at Sam's the other day and it's made by EcoLab. The label recommends a 1 to 10 dilution for soak tanks.... about $5.50 a gallon.
Thanks,
Flat Nasty with TAC 2008 event info.
"Sit tall in the saddle, hold y'ur head up high. Keep your eyes fixed where the trail meets the sky... and live like you ain't affraid to die. Don't be scared, just enjoy y'ur ride."
66fj40x2 is offline   Reply With Quote
Old 01-03-08, 11:08 PM   #21
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
Originally Posted by Poser View Post
I like MEK
I've used MEK professionally for bout 13 yrs... I sure hope you following the appropriate safety procedures with that shit. It'll fawk up your blood cells. I have lots of sick friends from MEK. It gives me nausea now. Lacquer thinners are not much better.
In some cites there are companies which go shop to shop changing out washer solvent. They distribute a low odour version of mineral spirits.
Varsol or Mineral Spirits is all I would use.
For the tard who suggested Avgas....don't use that in your parts washer. Chances are you will catch fire, get far too much lead in you too.
I've used avgas in a sprayer on oily engines to clean, but that practice is very old thinking.
One static spark is all it takes.
-91 FJ80, wife's ride
Old 01-04-08, 12:48 AM   #22
Beagles Rule!
D'Animal's Avatar
TLCA# 17104
Man, Hats off to you for using the search thread. Pulling a 4y/o one up is simply awsome.
I use stoddard solvent in my cold parts tank. In my Hot water parts washer I use water and Calgon automatic dish washing soap.
The harshest stuff we can get in California is simple green. They pulled the Catrol Purple stuff off most of the shelves a year ago.
Thanks,
D'Animal is online now   Reply With Quote
Old 01-04-08, 01:55 PM   #23
colangut's Avatar
TLCA# 3521
My friend Chris K. went the ER when that purple stuff ate all of the skin off his fingers. Ironically, he was using it as a safer version that a petro chemical. He had used simple green before and did not think he had to wear gloves. At the time, he did no realize that the purple stuff was different that simple green. Ouch.
I used low oder paint thinner. Works great. Look up the flash point, it's very similar to varsol which is very similar to what safety kleen uses.
colangut is offline   Reply With Quote
Old 01-04-08, 11:41 PM   #24
My grandfather was a blacksmith & my dad a tool & tie maker. Both always used plain kerosene to clean just about everything. I remember my dad especially would come home from bird hunting and just break down his Model 12 and let it soak in kerosene. I still use it, kerosene, and it does everything I want it to. Probably as much nostalgia as anything else that makes me use it. Don't know how the cost compares.
El Cazador is offline   Reply With Quote
Old 01-08-08, 04:49 AM   #25
66fj40x2's Avatar
TLCA# 10749
Ain't no tard noob here brother ...... a tard maybe but not a noob
I decided to try this purple stuff and some rubber gloves. I've got a nasty bell housing to clean up and some spare knuckle parts I never clean before tossing them in the "spares" box so I guess we'll see how it does.
Old 01-08-08, 05:48 AM   #26
Blue77FJ40's Avatar
Be careful with that Castrol purple stuff. It pulled off all the paint on my frame when I was only trying to degrease it. It also burned my hands, taking over three weeks to heal. I was used to simple green and didn't know I had to use gloves. Simple green's all I use on the truck now. It may take two shots, but at least it doesn't burn.
Varsol = mineral spirits, it's just a brand name. I use that to soak, but prefer brake fluid for small, quick jobs.
'77 FJ40: HFS, 33's, Locked and Low'd
Blue77FJ40 is offline   Reply With Quote
