Go Back   IH8MUD.com > General Tech Forums > Workshop and Home Improvement
Old 11-03-09, 07:39 PM   #1 (permalink)
climber8483's Avatar
Washing machine repair help
I was just given a Kenmore 80 series washer that only works every now and then. Everything seems to work fine, but it won't always fill with water. Any ideas? Switch gone bad or a solenoid? I was hoping to get clues where to work before I start probing around with the multi meter.
Thanks,
Brittain
"Red" 1970 Fj40 with a '78 2F, 4spd, front & rear discs, 8274, Jetta heated seats, 3" lift and 33 TSLs
climber8483 is offline   Reply With Quote
Old 11-04-09, 04:12 AM   #2 (permalink)
ff347's Avatar
TLCA# 16921
When it does fill with water is the flow of water just a trickle, does the hot water flow faster then the cold? If so it should be the solenoid.
This site will help too.
Appliance Parts from RepairClinic.com
Good luck,
Scott
And the plot thinnens.......................
Four seconds from now everything is going to look a little bit different........
100 and a 60
ff347 is offline   Reply With Quote
Old 11-04-09, 07:25 PM   #3 (permalink)
Wile E Coyote's Avatar
Poke around here, grasshopper. Fixitnow.com Samurai Appliance Repair Man: Do-It-Yourself Appliance Repair Help for all Brands and Models!
You will find your path to enlightenment.
The 2nd amendment...for when all the other amendments fail.
The desert dwellin, roadrunner chasin, soooper-genius!
'90 FJ 62, '08 Scion head unit, chopped quarters and rockers, 1" DIY body lift, bedlined exterior, and mostly stock. My soft wheeler and DD.
'85 Dodge Ramcharger a little built, and a little beat. She's looking long in the tooth lately.
Wile E Coyote is offline   Reply With Quote
Old 11-05-09, 03:14 AM   #4 (permalink)
