07-11-09, 05:29 PM
#1 | | 250+ Club
| Removing Nails from Cinder Block The owner said I could clear out some of the old work benches & shelves so I could have more room. The 2x4's were attached with a nail gun. Big frickin' nails too. What's the best way to get the 2x4 off w/o destroying the cinder block.
07-11-09, 06:52 PM
#2 | | Frame waxer
| Cat's Paw and a big honkin' pry bar.
You may end up pulling the heads off the nails. Just get the boards off, then snap the nails off flush with the blocks.
__________________ KB1OSF
'87 Toyota xcab SR5 - SAS'd, e-lockers, stuff (22RE/R151F/4.7's) - currently undergoing frame-off restore
'05 Lexus ES330 - Nav/ML/17's
'04 Toyota Highlander |
07-12-09, 07:15 AM
#3 | | 10k Club
| I would start with a catspaw or prybar to see if the nail will come out. If not, I would use a saws all and cut the board and the plate from around the nail head. I would then use the catspaw or prybar to see if the nail will come out again. If not, cut the head off the nail and drive it all the way in. |
07-12-09, 07:34 AM
#4 | | Addict
| C4 is your friend  agree with both statements above thats the way i would do it
__________________ 98 sr5 T100 34" SS LTB 2.5" lift, ARB front bumper, 8' plow 1994 FZJ-80 factory locked, 4" lift, Arb bumper, warn 12,000, snorkel, 35" TrXus mt, full belly skid, extreme air, bud built HD- TR & DR, HD 1/4 wall DOM control arms, 4x4 labs rear bumper with tire & gas can carriers, metal tech sliders.
1996 FZJ-80 factory locked, 4" lift, arb bumper, warn winch, HD 1/4 wall DOM control arms, 4x4 labs rear bumper with tire carrier
35"s |
07-12-09, 12:11 PM
#5 | | Forum Regular
Join Date: Apr 2007 Location: just short of the 49th parallel
| That nail and plate looks as if its been shot in with some sort of powder actuated fastening gun, ( Ramset or something like it). If you have to use anything larger than a flat pry bar behind the lumber, and have to use substantial force, the odds are fairly high that your going to at least pop a small part of the block face off. If thats fine, find the biggest damn pry bar you can find.
To get the cleanest look, Sawsall the nail behind the board, or split the board around the nail and then snap them off as noted earlier. Remember if those little bastards were put in properly, they're meant to stay in there under stressfull conditions, and their going to fight to come out.
__________________ 2000 100
89 62... needs work...lots |
07-12-09, 01:04 PM
#6 | | Lifer
| sawzall, otherwise you'll get familiar with stucco patch. |
07-12-09, 01:40 PM
#7 | | Lifer
| 4 1/2, or a die grinder with a cut off blade. Take the head first, and after the lumber is pulled, cut the shank flush with the wall.
__________________ '69 fj40 CSC#103 |
07-16-09, 08:51 AM
#8 | | Addict
| Quote:
Originally Posted by splitshot 4 1/2, or a die grinder with a cut off blade. Take the head first, and after the lumber is pulled, cut the shank flush with the wall. | x2... |
07-16-09, 08:12 PM
#9 | | Addict
| it's only gaining you 1 1/2" - incorporate it into the design of what you want to do.
work smarter, not harder.
bk
__________________ bk
KJ4HFL TLCA# 6909
'90 hilux crew cab, 4.3L vortec, marlin springs, marlin dual cases, and some other crap....
'71fj40 with ford v8 swap in progress
'03UZJ100 -  chariot |
07-17-09, 11:35 AM
#10 | | Addict
| Grind the nail heads off, remove the board, then grind the nails down. |
