01-20-08, 01:08 PM
#1 | | Lifer
| What Kind of Oil in Air Compressor? What type of oil do you typically run in an air compressor? If it matters, it's a small construction deal, not the nice belt driven shop type.
Can I use some of the motor oil that I've got laying around? (5-30, 15-40)
__________________ Cameron Mosley
'85 FJ60 - Daily Driver |
01-20-08, 01:53 PM
#2 | | You want to do what...?
| I think I used straight 30W. Must have read that someplace, maybe the manual.
__________________  : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar Tradesman full rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!).  : '03: 125K
DDs: ex-Accord (seller's remorse), Prius  : souped-up DR650 |
01-20-08, 02:21 PM
#3 | | Addict
| what mine said was to run Non Detergent 30w oil in it (ND30W) |
01-20-08, 02:38 PM
#4 | | Lifer
| Anything wrong with 5w-30? It lives outdoors at night and it didn't want to get started on some of the colder mornings... plus I already have some
01-20-08, 11:34 PM
#5 | | Lifer
| It probably has detergent in it. I've always heard to use non-detergent. Don't know why, but every manual I've read states non-detergent, so there must be a reason.
-Spike
__________________ His 1994 TLC 'White Elephant' +6"/37" Locked.
Hers '95 TLC Bare bones.
"Tolerance allows the weeds to overwhelm the garden"- Unknown |
01-21-08, 06:18 AM
#6 | | Lifer
| Thanks, I'll go track some down.
01-21-08, 06:47 AM
#7 | | 10k Club
| For an oil bath compressor, they make "air compressor oil" and it's available anywhere, even online. There is even a synthetic air compressor oil. I know Homo Depot sells it, and so does the local air tool place.
__________________ Andrew
1971 FJ-40 Rubicon tested, 85 2F (with a little help from my Cruiser brothers) , SOA, SM420, some mods--It abides
1976 FJ40 gone
1984 FJ-60 H41, Toybox, 4.56/ARBs, SOA, twin sticks and Rubicon tested
1989 FJ-62 138k-OME, daily driver-H55f
1997 FZJ-80 Driveway queen, with door dent and a new head gasket |
01-21-08, 07:12 AM
#8 | | Lifer
| Quote:
Originally Posted by Cruiserdrew For an oil bath compressor, they make "air compressor oil" and it's available anywhere, even online. There is even a synthetic air compressor oil. I know Homo Depot sells it, and so does the local air tool place. | Sears also sells them too. I would spend a few extra $$ and get the right stuff.
__________________ 69 FJ40 with some minor mods...
2000 Cummins powered Dodge with some power enhancements.
DO NOT SUPPORT TRAIL GEAR!!!!! bad ethics = bad business! http://www.paypalsucks.com |
01-21-08, 07:59 AM
#9 | | Lifer
| I've never looked specifically for the compressor oil, but I haven't run accross it when buying other crap in that department. I'll look a little harder next time.
01-21-08, 08:54 AM
#10 | | You want to do what...?
| I'm also curious about what the non-detergent issue is all about...
01-21-08, 02:56 PM
#11 | | 250+ Club
| Mobil Rarus 427 is fine for most regular "duty cycle" style compressors, it is a straight 30wt. Synthetics generally are required in the continous run style of compressors.
__________________ And the plot thinnens....................... Four seconds from now everything is going to look a little bit different........
100  and a 60 |
01-21-08, 03:47 PM
#12 | | Lifer
| Found some sythetic blend oil at Lowe's today... no wonder I've never seen it, they hide the very small selection that they do have! Quote:
Originally Posted by -Spike- It probably has detergent in it. I've always heard to use non-detergent. Don't know why, but every manual I've read states non-detergent, so there must be a reason.
-Spike | Quote:
Originally Posted by e9999 I'm also curious about what the non-detergent issue is all about... | On the bottle it said that regualar oils (10-30 types) will cause carbon buildup and shorten the equipment life.
01-21-08, 03:50 PM
#13 | | In the garage
| When I purchased my CH compressor around 10 years ago I called them to ask what oil I should put in it and their person on the phone told me regular old Mobil 1 10W-30 is what they were recommending until they came out with their own synthetic compressor oil. I change out the oil every year and it is still running strong. When this pump dies I will check it for carbon buildup. I bet the motor goes first though. |
01-21-08, 08:14 PM
#14 | | 250+ Club
| Any oil is better than no oil. I've bought ND oils for use in antique cars but can't remember exactly what the issue was. Not breaking down years of deposits?? |
01-22-08, 12:27 AM
#15 | | Lifer
| I have a bottle of Ingersoll-Rand oil that came with my IR compressor.
I filled it up when I got it 7 years ago, and haven't opened the bottle since.
__________________ Bailey Quintrell
'74 FJ40
'06 Tundra 4x4 LTD |
01-22-08, 09:10 AM
#16 | | Lifer
| Fortunately IR parts are available.
-Spike
01-22-08, 06:05 PM
#17 | | Addict
| Quote:
-Spike | sometimes they also say non-foaming as well. definately non-detergent tho.
__________________ 4/75 resto, COMPLETE!-sold. rig stays in god's country where it was born. '08 FJC- wifes rig sold... '06 tundra/work truck/estimating truck '99 100 series sold
2010 crew max tundra.
Black... |
