01-07-08, 06:39 AM
#31 (permalink)
Done!
All that is needed now…is to mount it on the vehicle and spool on the new cable.
Total parts: (New cable, Lower housing kit, Motor shaft bearing, Main shaft seal, paint) just under $75.00
I doubt I will be around to get another 24 years of service out of this winch, but someone will.
I paid about $460.00 for this winch….(bought new in 1983), I’ll bet it would fetch more than $600.00 today. Not a bad investment.
Flintknapper:
'97 Land Cruiser, Moonglow Pearl
Chocolate Lab (Kota), I miss you.
ΜOΛΩΝ ΛΑΒΕ (come and take them)
01-07-08, 07:11 AM
#32 (permalink)
Originally Posted by Blue77FJ40
WOW. Incredible job, both on the rebuild and the detailed article. Thanks!
Any thoughts on drilling the main-shaft end to accept a bolt? There have been tales of the brake assembly flying off along with the ball bearings when the split ring lets go. Gigglepin sells a kit for this, already machined.
I looked into that mod. and agree its a good safety measure for those who use this winch to extreme ends (in terms of braking and shock loading the cam gears).
I haven't babied mine any...and it has never come off in 24 yrs.
If ever a cir-clip has come off, it was because it was improperly installed at the factory or by someone else. If you look at it closely, it is slightly rounded on one side...but flat on the other. The flat side needs to face away from the brake unit. It's a pretty stout piece.
Drilling and tapping the main-shaft can be done, but be forewarned: That shaft is harder than the 5th grade was for Mike Tyson. So, have a few drill bits handy and a really good tap.
Seriously, if I were that concerned about the brake unit coming apart, I'd rig up a aux. "disc brake" on one end like the Brit's do with their competition 8274's.
I do like Gigglepin's improved friction material (larger size), so I might order those someday.
My next mod. will be the 6hp motor swap.
Flintknapper:
01-07-08, 04:06 PM
#33 (permalink)
Back in service
Back on the Bronco.
Ready for some more abuse.
Flintknapper:
01-07-08, 04:33 PM
#34 (permalink)
Nice Job!
I actually recently had my brake blow out the side, wrecking the needle bearing and the plate. I was thinking of rebuilding, but picked up a cheap winch that I could swap my good parts to (like my 24V motor). Anyway, any thoughts on what could cause that, like say no grease in the needle bearing? Also do you have any pics on the brake re-build? do you need speacial tools for that, or is it fairly strait forward?
Cheers,
Deny
01-07-08, 06:32 PM
#35 (permalink)
Originally Posted by Deny
Nice Job!
Cheers,
Deny
If you're talking about it blowing out the "motor" side....then yes....the needle bearing would have to of seized. I put a liberal amount of grease in mine and also put twice the recommended amount of oil in the case.
All parts depend upon "splash" lubrication and that can only happen after the lube has "climbed" the main gear.
As for the brake, no special tools are required. I used a pair of long nosed vice grips to compress the spring and hold the two halves together as one unit before installing it back on the shaft. But, it can be done a number of different ways.
I did not document the rebuild...as it has already been covered by another person. But I can walk you through it (very simple) if decide to do yours.
I have pics. of the upper end that I didn't post if anyone needs to see them. My main objective here was to "add" to the information already available, so others might benefit from it.
I went a little deeper into my winch disassembly than some folks do, I also added a few mods. (fill and drain plugs, zerk fittings on drum support, slotted solenoid cover) and wanted to share those as well.
Flintknapper:
01-08-08, 12:46 PM
#36 (permalink)
WARN 8274 rebuild
I have a WARN 8274 rebuild that I have started to rebuild, however, I am having difficulty getting the brake assembly disassembled.
Is there a trick to getting the brake assembly apart?
Did you remove the brake axle from the housing (i.e., replacing the shaft seal)?
Any guidance/suggestions would be appreciated.
Steve
01-08-08, 04:55 PM
#37 (permalink)
Steve
The brake assembly should come apart pretty easily UNLESS you have a build up of rust on the shaft or around the two key-stocks.
Remove the cir-clip, use a piece of emery cloth to smooth and clean up the main-shaft. Spray the "key stocks" as best you can with penetrating oil.
DO NOT use anything to “pry” the brake assembly off (using the case as a support).
If necessary… a small 2 jaw puller behind the rear brake disc should make easy work of it. The brake system is spring loaded...so it’s already trying to come apart.
Warning: As the "outer" brake disc moves off the shaft you will have 21 (count 'em) steel balls fall out. Do not lose any of these.
As the brake assembly comes apart, note the relationship of the parts to one another (very simple and self explanatory).
I did remove the Brake/Main-shaft on my winch in order to get to the main-gear in the bottom of the case. But, as long the needle bearing is in good shape and your current main-shaft seal is not leaking (not likely it would be) then there is no reason to disassemble/remove the main-shaft. The brake system comes off independently, just so you’ll know.
This is the needle bearing that the end of the main-shaft fits into (motor side of case)
And…this is the bronze bushing and seal (brake side of case).
You can see it all reassembled (just as it would be when you take your brake off) if you go back to post #24 where I “bench tested”.
Let me know if you have other questions or need additional pics.
Flint
Flintknapper:
01-09-08, 11:06 AM
#38 (permalink)
Bravo!
Great write up man!
Drew
Drew F.
Rising Sun 4x4 Club
01-09-08, 11:34 AM
#39 (permalink)
Originally Posted by REZARF
Bravo!
Great write up man!
Drew
Happy to help.
Lord knows...the guys here have helped me out in the past.
Flintknapper:
01-10-08, 12:44 PM
#40 (permalink)
WARN 8274 rebuild
Thanks for your comments.
I have not been able to remove the brake system from the shaft (apparently it is really stuck).
I was considering removing the brake system/shaft as an assembly and them removing the brake system from the shaft away from the Aluminum housing.
Does this seem possible?
When I attempted to remove the brake system/shaft as an assembly, it seemed to be butting up some resistance - my guess it is the shaft seal that is pressed into the housing.
The internal gear does not appear to be mechanically attached to the shaft (only attached thru the splines).
Perhaps I have being to careful and just need to apply a bit more force.
Appreciate your comments.
Steve
01-10-08, 02:34 PM
#41 (permalink)
Steve
Steve...have you tried using a puller yet. The brakes disc's should come off without too much trouble.
You can certainly remove the brake system and shaft as one unit. That way you could put it in a press if needed...but it really shouldn't require that much force.
To remove the shaft you'll need to split the case, pull up on the lock-plate and use a brass drift punch to drive out the shaft. The splined cam gear that fits on the brake-shaft is larger than the bronze bushing in the case. So, in essence you are driving the lip seal and bronze bushing out along with the shaft and cam.
The whole assembly will then come out.
I'll post some pics in a bit.
Flintknapper:
01-10-08, 03:23 PM
#42 (permalink)
This shows the lower end with brake-shaft, intermediate gear and main-gear.
Both the drum AND brake-shaft are held in place by the lock-plate.
Lock-Plate in down (locked) position:
In order to remove the either the drum or brake-shaft, you must pull up on it as pictured.
Lock-Plate in up (unlocked) position:
If you intend to remove the brake-shaft, use a brass drift punch against this surface only:
You will be driving out the lip seal, the bronze bushing and the brake-shaft all at one time.
IMO, there needs to be compelling reason to do this.
Flintknapper:
01-18-08, 09:27 AM
#43 (permalink)
Flintknapper,
Great writeup! Just what I was looking for.
I just picked up an 8274 that is either 1978 or 1988 (Date Code: BF8, S/N: 79xxx). I'm going to be tearing it down like you did yours and I know that I will need new cables from the solenoids to the motor. The wire in my cables look good (no corrosion), but the insulation has been weathered quite badly.
Are the cables that you mentioned in your parts list, the cables from the solenoids to the motor?
I'd be interested in some pictures of the upper half. On mine the clutch knob shaft is frozen in place. Will removing the four screws around the clutch plate allow me to remove the clutch shaft and assembly?
Did you try to check the bearings in your motor? Do you know if he motor is rebuildable? (bearings/bushngs)
Last question. What did you use to paint the drum? I'm probably going to use wire rope on it at first, and I'd like to use something that will help prevent the wire from starting new rust points.
Thanks for any info.
Michael R_
89 FJ62 - mostly stock w/ an H42 - ARB Bull Bar, OME shackles and Pins, OEM++ front springs, and a few dents
85 Mini-4x4 - stock - need to do rings
The opinions expressed here aren't even mine.
Don't take life too seriously son, you don't come out of it alive anyway. - Red Skelton
01-19-08, 08:01 AM
#44 (permalink)
No, the cable I mentioned was simply new wire rope for the spool, however.. the electrical cables are still avialable. There are three, you will need one of each.
5-1/2".....Part # 6007
6-1/2".....Part # 6008
7-1/2".....Part # 6009
The cover for the wire at the motor end is called a "nipple" and is Part # 2090.
Here is a source for parts. (These folks are not fast, so be patient.)
Warn Authorized Parts and Service Center: warnserviceparts.com
I'll see what pics I have available that I haven't already posted and place them here a little latter. Yes, removing the four screws will allow you to remove the clutch assembly. It has sealant around it, so you'll need to slowly pry it off. The shaft itself gets rusty... making it difficult to operate. Once cleaned and lubed...they work fine.
Be very careful not to drop the motor shaft gear into the bottom of the case (if you're not planning on splitting the case).
The bearing for the motor shaft is a 6203RS (double sealed), it's available anywhere, don't special order.
The bushing in the motor cap is replaceable, but most likely will be fine. Brushes are available, you'll just need to check yours for length. I wouldn't rebuild this motor if it needed anything other than brushes and bearings. You can buy a new motor off e-bay for about $100.00
Be advised, there are two types of motor shafts. One is splined and the other has a keyed shaft. If you buy a motor.. it will need to match your motor shaft gear (splined or keyed), OR...you can buy a splined motor shaft gear and mate it to a newer style motor. Also, there are other motors that will interchange (up to 6hp).
The black portion is Rustoleum Black Appliance Epoxy. I have used this for years on different items exposed to the weather. It is very tough. Wire rope and high tension loads...of course..will eventually take their toll, so nothing you use will be permanent.
Happy to help.
Flintknapper:
01-19-08, 07:24 PM
#45 (permalink)
Clutch mechanism assembled:
Clutch in “engaged” position:
Clutch in “disengaged” position:
Flintknapper:
01-21-08, 02:06 PM
#46 (permalink)
Big Thanks!
I've been watching this thread with great anticipation.
I've got a used 8274 on it's way  , it looks to be in great shape. But Flinknapper made it an easy decision even if it is'nt I'll know what to do to get back to new.
Thanks Flintknapper for the write up.
James
87 Fj60 196k and counting (((((Sold)))))
01-21-08, 04:35 PM
#47 (permalink)
James
I can assure you...there is nothing "scary" about refurbishing one of these.
If I can do it, anyone can.
Don't hesitate to ask questions, I am happy to help.
Flint.
Flintknapper:
01-21-08, 05:52 PM
#48 (permalink)
Outstanding thread Flint. I wish you had done this before I redid mine 2 years ago. It would have saved me a ton of effort/frustration and calls to Poser and Warn. Congrats.
Andrew
01-22-08, 08:28 AM
#49 (permalink)
Pinoy 4WD Journey
This is one of the great rebuilding thread. You did an awesome job!  I admire your skills, talent, attention to detail, and your time.
Originally posted by flintknapper
All of this for aesthetics of course. It serves NO purpose in terms of function.
My friend, yes it does serves a purpose and this is to prevent or minimize the corrosion on the mechanical parts that you just sandblasted, primed and painted. So it is not just for aesthetics look but for corrosion control too
Noel
97 LX450 unlock, IH8MUD decals, CDL/Pin7, HIRs, Cup Holder, 100 pads, GS LEDs, OEM grab bar, sidemarkers, ARB bar/XD9000, PIAA 520, 295/75R16 NTG, Kaymar Deluxe/tire carrier, OME850J/863, Slee speedo gear/SS brakelines/caster plates, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter, auto up and H2O temp mods. Need install: OEM subtank, BIC 95300B dual batt, blue fan clutch, OEM rear locker...
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, sliders
01-22-08, 10:51 AM
#50 (permalink)
Flintknapper:
01-23-08, 11:11 AM
#51 (permalink)
Flintknapper,
One last question.
Where did you get the stickers/decals to put back on the winch?
Those make it look like a brand new winch.
Michael R_
01-23-08, 02:01 PM
#52 (permalink)
Originally Posted by mkaustin
Flintknapper,
One last question.
Call or email “Stephanie” at Warn customer service and request a decal packet for an older model 8274. Warn Industries - Contact Us
The red “W” for the front of the solenoid cover is no longer available, but you can put the one from the packet on top of the cover as I did.
This is what you should receive after contacting her several more times to remind her (but be nice):
Flintknapper:
01-23-08, 08:03 PM
#53 (permalink)
I have a 8274 that I will be going through here shortly, and I have already bought the XP 6hp motor with XP solenoid pack, it should make it one hell of a winch.
The one mod I would like to do is the double motor setup using two 6hp motors from Gigglepin, but I don't think anyone in the states sell there stuff.
01-23-08, 08:37 PM
#54 (permalink)
Dog is my co-pilot.
Hi All:
"Flintknapper," awesome thread! Thanks for sharing with us all!
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
" The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
01-23-08, 09:23 PM
#55 (permalink)
The XP 6hp will be the next mod. to mine. I will be satisfied with that for my purposes.
The Brit's have done some pretty cool stuff with the 8274 for their competitions.
Double 6 hp motors, disc brakes, even water cooled dual motor set-ups.
I just need a good reliable winch for every day ranch work and the occasional vehicle recovery effort (usually someone else's).
This 8274 has served me well for almost a quarter century now. It was time to freshen it up...even though it was still running strong when I tore it down.
Flintknapper:
01-23-08, 11:31 PM
#56 (permalink)
bj74_guy?
Thanks for the thread Flintknapper. It looks like I'm about to do this myself with a condition unknown 24V 8274, so this is really useful.
Just curious, have you priced out one of those 6hp motors yet?
and by the way, your winch looks great!
norm
Coastal Cruisers
'85 BJ70, '89 BJ74, '92 M101cdn
01-24-08, 06:59 AM
#57 (permalink)
Finding a "deal" on the 6hp motor has proved to be impossible thus far.
If you don't know someone who works for a Warn dealer (and can get an employee discount), then plan on shucking out $400.00 or better.
The 6hp motor and "newer" 4.5hp motors use a 20 spline shaft.
Some of the older 8274's have a "keyed" motor shaft (and drive gear).
I mention this...because, you may need to buy a splined drive gear (called a Motor Pinion Gear) to go with the new motor if your old one was keyed.
A replacement 4.5 motor can be had in either configuration (keyed or splined) off of e-bay for between $85.00 & $125.00 respectively.
If anyone finds a bargain on the 6hp motor that comes on the XP 9.5
Warn winch, please post it here.
Thanks,
Flint.
Flintknapper:
01-24-08, 09:10 AM
#58 (permalink)
Well I got my XP motor and XP Solenoid pack, which was complete with controller and cables and the Pinion gear for a about $450.
I got it from a Warn service dealer on Pirate, right now I don't remember who it was but if I should remember I will post it, he was much cheaper then what you get off a website
I'll try and find it.
01-24-08, 10:53 AM
#59 (permalink)
Please do, that sounds like a heck of a deal!
Thanks,
Flint.
Flintknapper:
01-24-08, 07:34 PM
#60 (permalink)
Thanks,
Flint.
Well the guy I got it from was TasselsDesignLTD on Pirate.
Pirate4x4.Com Bulletin Board - View Profile: TasselsDesignLTD
Another guy could also try is Pat98TJ also on Pirate, He is from [url=http://www.offroadoverstock.com[/url]
Pirate4x4.Com Bulletin Board - View Profile: Pat98TJ
He post deals all the time on Pirate.
He was able to get me my 9.5Ti for $887 to my door.
Just PM them and ask, and if you don't have the #'s here they are.
Warn Part #'s
9.5XP motor #68608
Pinion gear #15879
XP Control pack #68609
