06-18-07, 04:47 AM
| | Forum Regular
Join Date: Oct 2006 Location: Bruthen, Victoria, Australia
| Winch Wiring Question G'day Guys,
I'm in the process of wiring in a second-hand Warn 9000 lb winch. There is a small black wire that has a tag on it saying "Ground Wire".
This slightly confused Australian would be extremely grateful is someone could tell him where this wire goes to and from
Cheers,
Ben |
06-18-07, 08:03 AM
| | Forum Lifer
| You can view/download the Operator's Manual from Warn...showing you how to install & connect: http://www.warn.com/truck/winches/src/XD9000.shtml
__________________ Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery with custom home brew battery tray, home brew sliders & Slee belly and skid plates, 9.5XP/Masterpull, Solstice LEDs, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, LT285/75R18 GY MT/R Kevlar, KK in tow... HAMified
ROTM: http://forum.ih8mud.com/100-series-c...pressomon.html |
06-18-07, 02:15 PM
| | I'm really very humble
Join Date: May 2004 Location: MN physically, MI spiritually
| I don't know squat about reading electrical diagrams, but the small guage wire is a ground for the control box and should be connected inside that box and then to an external chassis ground.
__________________ 94 FZJ80, factory locked with mods worth more than the truck.
06-19-07, 02:36 AM
| | Forum Regular
| Thanks Photogod. I checked your advice and you are 100 percent correct. You might be better at reading electrical diagrams than you thought. This wire runs from the plug to an earth point. This can be on the chassis or more commonly to the earth connection on the winch motor. Thanks once again. |
06-19-07, 12:00 PM
| | You want to do what...?
| not sure 100%, but IIRC there was a separate ground connector on the motor body for that wire, on my M12. But shouldn't hurt to put it on the main ground terminal, if it fits.
__________________  : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!  : '03: 115K
DDs: Accord, Prius  : souped-up DR650 |
