TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > VA/DC/MD- Capital Land Cruiser Club
Old 04-15-08, 12:23 AM   #31
colangut's Avatar
TLCA# 3521
Craig,
Might be tight with just a 2" shackle as you generally get about half the length of shackle length over stock - so a 2" longer shackle gives you about 1 inch of lift.
Did I remember this right? Bob, Dan, et al?
Go for a short lift spring like some used skyjackers and a shackle lift and you'll be in good shape. Other wise a 31 or 32" is about all you can run with just a shackle. Been there and done that.
You got all of the bugs worked out of that truck? Did you get the motor sorted out?
This thread is hijacked but it's all about the locals here huh...
JS
colangut is offline   Reply With Quote
Old 04-15-08, 06:10 AM   #32
That's "Greyt" "Andy"
greytandy's Avatar
TLCA# 16669
Originally Posted by breckbone View Post
I *think* the shackles that those pigs put on my 40 give it a 2" lift.
1970 FJ40 (AKA "Big Red")
2007 FJ Cruiser (Black Diamond )
greytandy is offline   Reply With Quote
Old 04-15-08, 07:41 AM   #33
Blue77FJ40's Avatar
Yeah, with just the 2" over stock length shackle, he's ony getting 1" lift. Not near enough for 33" x 12.50 tires. For every inch over stock length, you only achieve 1/2" of lift. and you don't want to go more than 1.5" over stock in the front, or you'll have steering problems. and then it's shim time.
OME lift kit is about 2.5" lift, and it's a tight fit at that. You probably get away with 34" skinny tires... maybe. I think that's what Charleton had.
'77 FJ40: HFS, 33's, Locked and Low'd
Blue77FJ40 is online now   Reply With Quote
Old 04-16-08, 07:24 AM   #34
Magic on the Mic
Felix's Avatar
TLCA# 15204
I'm not sure a 2.5" lift will clear 34s w/o some cutting [this statement is incorrect]. Charleton currently runs 32x10.50s [I think this one is okay].
Felix
'75 FJ40 - kinda stock-ish
Felix is online now   Reply With Quote
Old 04-16-08, 09:00 AM   #35
Blue77FJ40's Avatar
It's the narrowness of the tire that allows them to tuck inside the rear fenderwell. Especially when mounted on the stock rims. I thought it was Charlton, if not, can't remember who it was with the 34 skinnys. Cerainly 33 skinnys will definitely work, but 34s are best tested first before purchase, if you can.
What's your tire status, Felix?
Old 04-16-08, 11:07 AM   #36
colangut's Avatar
TLCA# 3521
Originally Posted by Felix View Post
I'm not sure a 2.5" lift will clear 34s w/o some cutting. Charleton currently runs 32x10.50s.
Like Dan said, this works because of the tire tucking up into the fender wells. I've run this setup myself back in the mid 90's, a guy here in LA runs the Rubicon with this setup and Jason V. does as well. Like an idiot, I took this setup off my truck in 1993-94 and went to 36's because "bigger is better". I often looked back and wished I'd just left well enough alone.
Here is a post about the 34's
http://forum.ih8mud.com/40-55-series...-swampers.html
I've met this guy and seen the truck in person, it's well tested
Old 04-16-08, 12:20 PM   #37
Magic on the Mic
Felix's Avatar
TLCA# 15204
Yeah, I realized I was probably wrong after I posted that. I think was mixing up 2.5" lift with 2.5" shackle in my head.
My current tire status is "hoping to buy the aforementioned Charleton 32s in the near future." I'd hoped to just get a new set, but the recent replacement of all four tires on my wife's Mini Cooper S has taken a bite. For the record, run-flats suck.
Felix
Felix
Old 04-16-08, 01:09 PM   #38
colangut's Avatar
TLCA# 3521
Felix,
I was shocked at what the tires on my wifes BMW cost to replace.
Next time check tire rack.com
-JS
Old 04-16-08, 01:23 PM   #39
In the garage
John Smith's Avatar
TLCA# 9074
Felix, Is she taking the car to the track? We have the run flats on our S and I just rotated them last weekend. The rears had no real wear and the fronts have a ton of life left. Ours are the Pirelli run flats. My co-worker has an older S with the Goodyear run flats with a ton more miles and still has life on the original tires.
My father weekend races his M3 at the track and can go through a set of tires in a weekend. And I thought tires were expensive for our trucks...
79 FJ40 & 78 FJ55
John Smith is offline   Reply With Quote
Old 04-16-08, 05:06 PM   #40
colangut's Avatar
TLCA# 3521
I don't know about Felix's wife, but mine goes through tires.
She's had two honda S2000's both of them the tires were shot at 10K miles.
On her current 330 BMW, the tires show signs of wear at 4000 miles.
I think she drives like she's on the track.
I made her sell the S2000 after she spun it a few times on back roads.
I literally can't take a cup of coffee in the car when she drives, even in the minivan. There is no hope of not spilling it.
She blew up the motor in her SLK at 10K miles and fried the clutch in her GTI at 36K miles. Hard on cars...
Perhaps Felix's wife drives the same way.
-JS
Old 04-17-08, 01:12 AM   #41
grown up MOD
reffug's Avatar
TLCA# 14549
-JS
Man you need tougher tires.................
Or a different wife.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
reffug is offline   Reply With Quote
Old 04-17-08, 12:00 PM   #42
Magic on the Mic
Felix's Avatar
TLCA# 15204
My wife drives fast, but she's never had tire troubles like she's had with these. These were also Pirelli, eufori, I think. Yeah, we forgot to rotate (and the dealer didn't do it at the 10K service), but at 14K miles the fronts had just about no tread. The rears had great tread, but each had a hole. One was punctured about 5 months ago in the middle of the tread and was repaired by a local place. The other just ate a drill bit, at least 1/4 inch. It was close enough to the sidewall to prohibit repair.
I figured that with two bald fronts and a patched-up rear, I needed a new set. The shop guy who mounted the new ones (non run-flat) mentioned that he's seen a lot of damage on run-flat tires. They need to run while flat since the tread is so delicate.
My in-laws had a MINI with run-flats that are toast at 14K miles, too.
Felix
Old 04-17-08, 02:49 PM   #43
In the garage
John Smith's Avatar
TLCA# 9074
I guess I should consider myself lucky so far.
79 FJ40 & 78 FJ55
Old 04-18-08, 09:56 AM   #44
cahilc's Avatar
Location: Silver Spring, Maryland & Daytona Beach, Florida
Naw, I think that wife is perfect ... What I think you need to do is get her a track specific car and get into a local race club and start accessing the race tracks when they have club time.
Now there's a 'woman' with a need for 'speed' ... WOW !!!
Cahil
P.S. Hold onto your 'britches' because that kind of behavior usually doesn't go away by itself. Needs to be releases somewhere, either at the track or ... ???
67 Red FJ40 - SBC, Holly, NV4500, SOA
87 Blue FJ60 - Cummins 6BT, NV4500, OME, SUA
..... coupla' parts rigs too ...
cahilc is offline   Reply With Quote
YOU MAY CONTACT US AT MEMBERSHIP@TLCA.ORG | (800) 655-3810 | PO BOX 230, VERONA, KY 41092
