TLCA HOME
: BOARD & BYLAWS
: EVENTS: MERCHANDISE
: BUSINESSES
: PHOTO GALLERY
: CLASSIFIEDS HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS |
How stiff is your ......
...... trailer????
Roger, Kowboy (Greg or Brian)??? Just got home with the GN and man it's got a lot of flex in the frame. Maybe too much to mount the camper without damaging the camper. How can take some of the flex out of it without causing other issues with the trailer? Sorry for the tech
__________________ "A government big enough to give you everything you want, is big enough to take away everything you have." ~ Thomas Jefferson And yes, I'm on of those "Rural American's" that clings to his guns and his religion!
Unwise One
I know mine's a limp noodle with the camper on 'er. You can grab the corner of the camper with one hand and flex the trailer all the way to the back.
![]() I ain't towin' it like that for damn sure. Weldin' friend of Greg's that has built a buncha trailers is goin' underneath my gooseneck and bracin' up the two main I-beams somehow ... ![]() I think he adds big pieces of pipe across the beams ev'ry so often. He's also gonna jack up the middle and pre-strees it up with some braces of some sort ... kinda like the 18-wheeler flatbeds arch up when they're empty. ![]() Best I can tell ya Brother. ![]()
__________________ I'm the President of The White Trash of the Elwood Chapter and Proprietor of The 3X's Ranch and Retirement Home .... and you ain't. ......
Needs more triangulation...
![]() Chris
If your latteral bracing is level on the bottom of the trailer, lay a 10 foot piece of 1/4 inch x 3 inch bar stock at an angle and weld on both sides of the stock at each cross brace that will be a good start.
then run some tube from the outside top to the bottom of the I-beam every 4 feet, that should stiffen it up good __________________ 1988 FJ62 buggy SOA front 4-link rear crawl box lockers C3 beadlocks 38"TSL/SX ram assist 30 splined chromo rears 6 studded rear disc Warn RC rear Warn 8274 front Baja SS seats G-Force Race harnesses 1989 FJ62 Ome HD 4" w/35's 1991 FJ80 w/33's 2006 F350 King Ranch |
Nothin's level with anything.....
Thinkin' of either runnin' channel front to back and puttin' the deck flush with the top of the side frame or just puttin' the deckin' on the crossmembers that are here now and having the deck sit about 1.5" lower then the top of the side frame. I've posted this in trailer tech on Mud & Pirate and have got nothing..... Thanks, __________________ "A government big enough to give you everything you want, is big enough to take away everything you have." ~ Thomas Jefferson And yes, I'm on of those "Rural American's" that clings to his guns and his religion!
Mine is fairly stiff, I did not hard mount my camper. I used the spring loaded tie downs that I used with the pickup mount. If the decking is off the trailer it will have extra flex. If the flex is front to back a truss support under the frame will stiffen it up.
__________________ Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html ![]() Roger FJ-40/6.2L Diesel STLCA White Trash of the Elwood Chapter VP SFWDA |
Where is the flex Mike? Front to back or corner to corner? Front to back can be strengthed fairly easily with what I call a bridge truss added to the bottom of the frame rails(see my another new project thread). If it's corner to corner you should be able to brace from the front corners to just in front of the axles to eliminate most of it. I would suggest looking into installing cables in a cross pattern with a turnbuckle on each. Should be fairly easy to fabricate and very strong. (as in holds up bridges and shit). Just my $.02.
