TLCA HOME : BOARD & BYLAWS : EVENTS: MERCHANDISE : BUSINESSES : PHOTO GALLERY : CLASSIFIEDS
HISTORY : TOYOTA TRAILS : MEMBERSHIP : CLUBS : MISSING VEHICLES : LAND USE : CHAT : LINKS
Go Back   IH8MUD Forums > TLCAForum.com > Toyota Land Cruiser Association Forum > Clubhouse Corner > TX- Alamo City Land Cruisers
Old 02-26-08, 09:00 PM   #1
ilikebigtires's Avatar
Automotive Lift
Ben, I think you need one of these...
Automotive Lift
ilikebigtires is offline   Reply With Quote
Old 02-26-08, 11:51 PM   #2
Bear80's Avatar
TLCA# 14779
I think at only 24" of lift it would bearly be close enough to lift either of my trucks.
40th FZJ80 - Range Rover Recovery Vehicle
-Benjamin-
Bear80 is offline   Reply With Quote
Old 02-27-08, 09:23 AM   #3
x2 very true!
-ADAM-
"Post count does not equal knowledge"
2001 Tacoma ---"The TEXAS TANK"
-enough to do the hard stuff
Rockwieser is offline   Reply With Quote
Old 02-27-08, 04:36 PM   #4
rrdogma's Avatar
TLCA# 18040
I wish we had snapped a pic of all of us sitting under Ben's truck without raising it at all.
1982 FJ40 -stock-original owner "Baby"
1997 FZJ80 - locked 'n stuff
Lone Star Land Cruisers-Austin
rrdogma is offline   Reply With Quote
Old 04-02-08, 09:50 PM   #5
TejasYOTA's Avatar
TLCA# 18885
Cool Get this lift!
The lift he would need, if it was a sissors lift is this one from BendPAK
SP-7X
Lifting Capacity 7,000 lbs. / 3182 Kg.
Lifting Height 72” / 1829 mm.
Lowered Height 5” / 127mm.
Overall length 165-1/4” / 4197 mm.
Overall Width 81” / 2057 mm.
Pad Length (adjustable) 63” - 71” / 1600 mm. – 1803 mm.
Pad Width 22” / 550 mm.
Lifting Time 45 seconds
Width Between Pads 32” / 790 mm./td>
Motor (*) 220 VAC / 60 Hz. 1Ph.
This is the one I am thinking of getting for my garage, because my ceiling is low (okay normal garage height).
No way to do a 2-post, with out structual changes to the rafters above.
Cya,
Nathan
2001 Tacoma DCab
BIG THANKS to the following guys/gals that design killer stuff for my rig: JFab of San Marcos TX, CBI, Donahoe, TC, Timbren, Alcan, R.O.R.E., ViAIR & ARB.
www.Z3POWER.net
TTORA Member since Nov 18, 2005 - - TLCA Member since June 4, 2008
TejasYOTA is offline   Reply With Quote
Old 04-03-08, 10:31 PM   #6
If you get that you'll have to host all future wrench-a-thons...
Old 04-03-08, 10:38 PM   #7
LandCruisers4Life's Avatar
TLCA# 16244
I wonder how much it is..... I think I'd like one of those
2004 Land Cruiser UZJ100 "El Rinoceronte"
Only 100 Series on earth with an Inti rack on top.
LandCruisers4Life is offline   Reply With Quote
Old 04-05-08, 07:39 AM   #8
TejasYOTA's Avatar
TLCA# 18885
Cool
Lowest I have seen is $3,500 with shipping included.
Just need to make sure if it is to a shipping depot or if it is to your home, that you have the means to take if off their semi or if they have a drop lift on their trailer.
Cya,
Nathan
2001 Tacoma DCab
www.Z3POWER.net
Old 04-05-08, 08:38 AM   #9
TejasYOTA's Avatar
TLCA# 18885
Cool
When i was looking at lifts...this is the one I really would rather have.
It's a 2-post version that fits in low ceiling heights.
BendPak XP-9FX
Lowest price on this is around $2,700 (with or w/o shipping included).
To have this installed in my garage, I would have to do some changes to the rafters. I would need to discuss this with an architect to see if this can be done so I could lift a car/truck high enough.
Features
9,000-pound lifting capacity
Short column for low-ceiling installations
Wide or narrow configuration
Single-piece columns
Single point safety release
Chain lifting system combined with dual hydraulic cylinders
Electric / hydraulic power system
Large, 20" x 19" steel base plates
Self-lubricating dura-glide polyethylene bearing system
Safety locks in each column spaced every 3-inches
Automatic arm restraints
Heavy-duty dual 3/8” equalizer cables with oversize sheaves
Truck and van adapters standard
Specifications XP-9FX
Lifting Capacity 9,000 lbs. / 4082 kg.
Height Overall 128" / 3251 mm.
Width Overall (Outside of Base Plate) 145" / 3683 mm.
Width (Outside of Columns) 137" / 3480 mm.
Cover Height 2" / 51 mm.
Inside Columns 115" / 2921 mm.
Reach (Front Arm Min.) 35" / 889 mm.
Reach (Front Arm Max.) 52" / 1321 mm.
Reach (Rear Arm Min.) 35" / 889 mm.
Reach (Rear Arm Max.) 52" / 1321 mm.
Min. Pad Height(*) 4-1/2" / 114 mm.
Rise 72" / 1829 mm.
Max Lift Height (Pad Only) 76" / 1930 mm.
Max Lift Height (6" Adapter) 82" / 2083 mm.
Drive-Thru Clearance 106" / 2692 mm.
Motor (**) 220 VAC / 60hz. 1ph.
* Low profile arms are available as an option.
The low profile arms would work for my low riding Z3 or any other sports car I may own in the future.
Cya,
Nathan
2001 Tacoma DCab
www.Z3POWER.net
YOU MAY CONTACT US AT MEMBERSHIP@TLCA.ORG | (800) 655-3810 | PO BOX 230, VERONA, KY 41092
