Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > General Tech Forums > Trailer Tech
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
Trailer Tech Whether you haul your vehicle on it, or your gear in it....
Thread Tools Display Modes
Old 08-26-09, 08:12 PM   #1
BJ42Gringo
BJ42Gringo's Avatar
4-pin wiring for Military-style lights on a m416?
My m416 has brand new 4-pin wiring, but I'd like to swap in M-series lights (with LED). How do I wire them up using the standard 4-wire trailer wiring since they have the military outputs? I don't have the original military wiring harness/plugs, so that's not an option. Thanks in advance.
"The Yellow Brick" - 1982 RHD BJ42, NZ Spec with Turbo/H55 and OME 2.5
1997 LX450
1966 M416 Trailer
BJ42Gringo is offline   Reply With Quote
Old 08-27-09, 06:37 AM   #2
kilo
kilo's Avatar
They are standard connectors inside of the rubber guards that the lights come with. Either male or female. I switched to 4 wire and I just cut them off and spliced with regular butt connectors and works fine.
kilo is offline   Reply With Quote
Sponsor 08-27-09, 07:44 AM
Sponsored Link
advertisement
Old 08-27-09, 07:44 AM   #3
BJ42Gringo
BJ42Gringo's Avatar
Ok. So it looks like there are 5 wires coming out of the light housing, right? How exactly do you hook up the 2 trailer wires to the 5 light wires? Pics might also help me see how you do it.
1997 LX450
1966 M416 Trailer
Old 08-27-09, 08:07 AM   #4
kilo
kilo's Avatar
I misunderstood. I'll take some pics later today for you. Mine had some metal crimps that where numbered. If you search here or maybe somebody will chime in, you'll fined the lay out for it. I'll look for it as well.
Old 08-27-09, 08:25 AM   #5
BJ42Gringo
BJ42Gringo's Avatar
No rush, much appreciated!
1997 LX450
1966 M416 Trailer
Old 08-27-09, 08:55 AM
kilo
This message has been deleted by kilo. Reason: wrong info
Old 08-27-09, 11:26 AM   #6
Koffer
Addict
Koffer's Avatar
I'll have to look at mine
the nice thing with the lights is there should be a metal tag with a # on it . I'll see about getting the # that does the brake and running light . With the LED lights they run a extra wire for the ground . The connectors are just male bullet connectors under a rubber boot .
Todd
64' FJ40, 86' BJ70, 96' FZJ80 , 66'M416 and a 92' M101CND
Koffer is offline   Reply With Quote
Old 08-28-09, 01:17 PM   #7
Living in the Past
Lifer
Living in the Past's Avatar
Not sure what the M series light is. I take it that is the style with black out lights? If you remove the lens and use a meter it shouldn't be real hard to figure out what wire goes where. Think the later style was solid state but also 24volt. I went with Gama Goat lights on my M416. Only used two of the three sockets. Installed different wattage 12 volt bulbs. My wiring harness was still ther so I made the connection for the four pin at the front junction box
Living in the Past is offline   Reply With Quote
Old 08-31-09, 04:32 PM   #8
kilo
kilo's Avatar
Sorry I have taken so long. I hope this helps. Your lights should have male connectors with rubber boots to seal.....I crimped on female ends and plugged together. I left the rubber boots on, I should be able to find the counter parts to make them seal up real good.
Your lights should also have some small aluminum tags crimped on them with ID numbers? Mine did and here is what goes where....
Drivers side I have YELLOW going to 22 and BROWN going to 21.
Other side is GREEN to 460-461 and again BROWN to 21. Your WHITE is the ground anywhere you would like. The remaining plugs I left alone and tucked away.
I also added some marker lights in the front corners for some BLING BLING and both of them are connected to the BROWN.
Don't forget to swap out your bulbs to 12v. Hope this helps you and again sorry it took so long kind of hard to get things done with a cold beverage in hand.
Old 08-31-09, 04:38 PM   #9
BJ42Gringo
BJ42Gringo's Avatar
Kilo - you the man. Thanks!
1997 LX450
1966 M416 Trailer
Old 08-31-09, 05:09 PM
Sponsored Link
advertisement
Old 08-31-09, 05:09 PM   #10
kilo
kilo's Avatar
Let us know if it works.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
